Task Factory Terminator Destination
| Destination Icon | Destination Description |
The Terminator Destination is used to quickly add an end to a data flow. It requires zero configuration. Simply add an output to the terminator destination. To use the advanced features to generate an output file, you can open the Terminator Destination and define how you want the output file to be defined. |
Input Columns
The Terminator Destination is also used to define the end of a Data Flow Nugget. Select the include box to define an output column in the Data Flow Nugget Transform.
File Output
| Option | Description |
| Generate Output File (selected input columns are included) | Select this to generate an output file. |
| Output File Path |
Select the path to output the file to. |
| Column Separator |
Choose the character to use to separate columns. |
| Row Separator |
Choose the escaped character to separate rows. |
