Documentation forTask Factory
Task Factory Hash Transform
Hash Transform
Transform Icon Transform Description
Task Factory Hash Transform Icon The Hash Transform is used for creating sets of hash values as new output columns from one or more input column.
Output Columns
Option Description
Add Column Creates a new output column output with the hashed value once configured.
Remove Column Removes the currently selected column.
Output Column The column name to be output.
Algorithm The hashing algorithm to be used by the output column.
Input Columns
Option Description
Include Column
Selects the input column to be hashed.
Input Column
The name of the input column.
Order
When combining columns, users can change the sequential order of the input columns by selecting the up and down buttons.
Enable Padding
Toggles the ability to include column padding in the output.
Null Replacement Character(s)
Users can replace Input Column NULL values with a designated character.
Separator Character(s)
When combining columns, this character is added between the selected columns.
Note:  The pipe character | is used by default when no value is entered.
