Task Factory Timezone Conversion Transform
| Transform Icon | Transform Description |
The Timezone Conversion Transform easily converts a date from one Timezone to another using the IANA TZ Database. Note: The Timezone Conversion Transform automatically accounts for daylight saving time (DST) adjustments. |
Original Timezone / Converted Timezone
| Option | Description |
| Source | Select where the original Timezone data is found. This can be one of three types :
| Enter Static Value / Variable, Input Column | Depending on where the source is stored, you use this text box to point to the source. |
Source and Output
| Data Source Column | The column where the original date is retrieved. Note: This column must be a date, DBTimeStamp, or DBTimeStamp2 data type. |
| Output Action | Where the converted data is sent. There are two options.
