Task Factory Error Output Description Transform
Note: The error output description allows for multiple error outputs from other components.
| Transform Icon | Transform Description |
The Error Output Description Transform is used to add descriptive errors to your data flow components. To use the Error Output Description Transform, add the error output of a source or transform components to the error description and then output the more descriptive error data to a destination. |
Input Columns
| Option | Description |
| Output | Select this option to include original column in the output. (The box next to Output selects all columns.) |
| Alias | Select inside to rename the column. |
| Input | The input type of the information source. |
| Input ID | The input ID of the information source. |
| Lineage ID | The Lineage ID for the information source. |
