Task Factory Case Transform
Case Transform
| Transform Icon | Transform Description |
The Case and Standardization Transform is a transform that allows the user to format the case of source data using different styles of formatting. |
Actions
In the Choose Action column, selecting on the <No Action> tag displays the choose action drop down menu.
Action
Note: By default no action is selected. Selecting an action opens the parameter options.
| Option | Description |
| Convert string to proper case | This action is used to transform the case of source data. |
Output Action
The Case Transform has the two output options:
| Replace the column data with fixed data |
| Output the fixed data to a new output column | If selected, the new output column name is inputcolumn_output. For example, if the source column name is FirstName, the output column is FirstName_output. |
Parameters
Note: Parameters become available once an action is selected.
| Style |
Select the style table to use, when SimpleProperCase is selected then all other parameters are ignored. |
| Convert Irish Surnames |
Set true or false to indicate whether or not to convert Irish surnames. ex. OHARA converts to O'Hara. |
| Use Typographic Apostrophe |
Set this property true or false to indicate whether or not to use the typographic apostrophe in place of the standard apostrophe when converting Irish surnames. |
| Correct Common Misspell |
Set this property true or false to indicate whether or not to correct common misspellings. ex. acn is corrected to can. |
| Alphanumeric Upper |
Set this property true or false to indicate whether or not to convert alphanumeric data to all uppercase. |
| No Vowels Upper |
Set this property true or false to indicate whether or not to convert alphabetic data containing no vowels to all uppercase. ex. mlk converts to MLK. |
| Ignore Mixed Case |
Set this property true or false to indicate whether or not to convert mixed-case text. Use this setting to preserve existing mixed-case text. Text only converts when Text-In string is all uppercase or lowercase. |
Additional Information: See the Task Factory Error Row Handling article for more information about this functionality.
