Task Factory Delete Batch Transform
Additional Information: Please see the Azure Support page for more information before using this component with Azure databases.
| Transform Icon | Transform Description |
The Delete Batch Transform allows you to quickly delete batches of data. |
General Tab
Delete Batch Information
| Option | Description |
| Connection Manager | Select an existing connection manager if available, or create a new one. |
| Table to delete rows from | Choose the table where you want to delete rows. |
| Command Timeout | Set the number of seconds before the command times out. |
| Turn off internal transaction? |
Only use this option for performance reasons. It has the potential to send some data and not others if there is an error.
Select Keys to be used to delete rows in the selected table
Map the columns from the source to the columns in the destination to be used to delete the rows in the selected table.
