Documentation forTask Factory
Task Factory Address Management
Address Verification Connection Manger
Icon Description
Task Factory Address Verification Connection Manager Icon The Address Verification Connection Manager is used to connect to your USPS database and Assemblies.
Task Factory USPS Database / Assemblies Location Connection Manager
Option Description
Database Location The file path to the dvd_comm extracted folder. Selectto open the Browse For Folder window, and then select the appropriate file path. Select OK to save your connection.
Assemblies Location The file path to the ams_devkit extracted folder. Selectto open the Browse For Folder window, and then select the appropriate file path. Select OK to save your connection.
Address Parse Transform
Transform Icon Transform Description
Task Factory Address Parse Transform Icon The Address Parse Transform is used to parse unformatted address data and transforms it into USPS standardized address data.
Address Data Input
Task Factory Address Parse Transform Address Data Input
Input Options
Option Description
Single column contains all address data Use this option when all of the address data from your source is contained in a single column.
Address data is spread across multiple columns Use this option when the address data from your source is not contained in a single column. You choose which column from your source contains the address element needed by the transform.
Use the address data input tab to map the source input columns to the appropriate address elements in the address parse transform. Your source does not have to contain a one to one relationship to the address elements in the address parse. You can map a single column from your source to multiple address elements in the transform. For example:
AddressLine1 column: Address
AddressLine2 column: Address
City column: CityStateZip
State column: CityStateZip
PostalCode column: CityStateZip
Address Quality
Task Factory Address Parse Transform Address Quality
The address parse assigns a level of quality to two sections of the address:
  1. Address Line 1 and Address Line 2
  2. City, State, and Zip
There are three levels of quality that can be assigned to the two sections of an address:
High Medium Low
  • Address Line 1 and Address Line 2 - The address is technically complete
  • City, State, Zip - These fields are technically correct
  • Address Line 1 and Address Line 2 - The address is complete but missing a part of the address like apartment number or street suffix
  • For Address Line 1 and Address Line 2 - The address is not verifiable
  • For City, State, Zip - Either the City, State, or Zip Code is missing
When the address parse runs it parses out the data and assigns the level of quality based on whether it can find a valid address and a valid city, state, and zip according to the rules above. You can either include all of the address as part of the output from the transform or you can select Include only high quality parsed addresses. Selecting this means that the output named Parsed Address Output contains addresses that are considered high quality. If you choose this option you must also make a selection from the What should happen to non-parseable (low quality) addresses? drop down menu.
Option Description
Ignore Failures This option skips the addresses marked as low quality.
Redirect Errors to Error Output This option redirects the rows to the error output.
Fail Component This option fails the component when the first invalid address is found.
Redirect Errors to Non-Parseable Output This option redirects the rows to the Non-Parsed Address Output.
Parsed Output
Task Factory Address Parse Transform Parsed Quality
The Parsed Output tab defines how you want the parsed address data outputted from the transform. By default there are new columns for each address elements and quality elements as part of the Parsed Address Output.
Output Columns
Column Description
Address Data Column The address data column defines the data that is output from the transform.
Action Column The action column defines whether the output contains a new column or the data in an existing column.
  • Add New Column - This tells the transform to add a new column to the output. The columns to the right of the action column are used to define the properties of the output column. The data for the respective address data column is contained in the output column defined in the Output Column Name column.
  • Replace Column - This tells the transform to replace the data in a source column instead of using an output column. You need to select the name of the source column to replace in the Output Column Name column. If this option is selected, all of the columns to the right of Output Column Name are now read-only.
Output Column Name Defines either the name of the output column if Add New Column is selected in the Action column or the name of the source column to replace if Replace Column is selected.
 Output Data Type Choose the output data type.
Output Length Define the length of the column.
Code Page Change the code page.
Output Case Formatting Defines how the output is determined:
  • Proper Case - This transforms all of the data in the parse address to proper case (First letter of every word is upper case).
  • Upper Case - This transforms all of the data in the parse address to upper case.
  • No Case Formatting - This does not transform the case of the data.
Address Verification Transform
Important:  Address Verification Transform is available for SQL versions 2012 and higher.
Address Verification Transform must be run in 32-bit mode. An internet connection is required to update the Address Verification database.
Task Factory Address Verification Transform Icon The Address Verification Transform uses the USPS database to verify United States addresses.
Source Data
Task Factory Address Verification Transform Source Data
Option Description
Connection Manager Select the Connection Manager for the Address Verification Transform.
Firm Name Source Column (Optional) Maps the column that contains the person or firm's name.
Address1 Source Column (Required) Maps the column that contains the first address line.
Address2 Data Column (Optional) Maps the column that contains the second address line (e.g. suite or apartment numbers, building name, etc.)
City Source Column (Required) Maps the column that contains the city.
State Source Column (Required) Maps the column that contains the state.
Zip Code Source Column (Required) Maps the column that contains the zip code.
Urbanization Source Column (Optional) Maps the column that contains the urbanization code for Puerto Rico addresses.
Unverified Address Behavior Options for handling unverified addresses:
  • Ignore unverified (unverified addresses will be skipped) - Skips the unverified address and continues execution.
  • Redirect unverified to unverified output - Redirects all unverified addresses to a designated unverified output.
  • Fail upon first unverified address found - Fails the component as soon as an unverified address is encountered.
Output Columns
Task Factory Address Verification Transform Output Columns
Option Description
Address Data Column Identifies the column.
Column Behavior Users can choose between the following:
  • Replace Column
  • Add New Column
  • Do Not Output Column
Output Column Name Users can change the name of the output column.
The following list details the Address Verification Transform's output:
Column Name
Data Type
Length
AddressLine1
DT_WSTR
255
AddressLine2
DT_WSTR
255
City
DT_WSTR
255
State
DT_WSTR
3
ZipCode
DT_WSTR
10
ResponseCode
DT_I1
0
AbbreviatedCity
DT_WSTR
255
AddressComponentChanged
DT_BOOL
0
AddressKey
DT_WSTR
255
AddressNotFound
DT_BOOL
0
AddressStandardized
DT_BOOL
0
AllOrPartFirmLineUsedForAddressLine
DT_BOOL
0
BetterAddressExists
DT_BOOL
0
CarrierRoute
DT_WSTR
255
CarrierRouteRateSortIndicator
DT_WSTR
255
CityStateCorrected
DT_BOOL
0
CountyCode
DT_WSTR
255
DeliveryPoint
DT_WSTR
255
FirmName
DT_WSTR
255
FirstPostDirection
DT_WSTR
255
FirstPreDirection
DT_WSTR
255
FirstSuffix
DT_WSTR
255
IncorrectSecondaryNumber
DT_BOOL
0
InsufficientIncorrectData
DT_BOOL
0
InvalidCityStateZip
DT_BOOL
0
LookupStatus
DT_WSTR
255
MainPostOfficeOutputCity
DT_WSTR
255
MainPostOfficeOutputState
DT_WSTR
255
MatchedPrimaryNumber
DT_WSTR
255
MatchedSecondaryNumber
DT_WSTR
255
MilitaryMatch
DT_BOOL
0
MissingSecondaryNumber
DT_BOOL
0
MultipleResponseCanBeBrokenUsingTheLowestZip4
DT_BOOL
0
MultipleResponseDueToMagnetStreetSyndrome
DT_BOOL
0
NoMatchDueToEws
DT_BOOL
0
NonPoBoxDualAddress
DT_BOOL
0
NoZip4Assigned
DT_BOOL
0
PoBoxDualAddress
DT_BOOL
0
PrimaryName
DT_WSTR
255
PrimaryNumber
DT_WSTR
255
RuralRouteNumber
DT_WSTR
255
SecondaryNumber
DT_WSTR
255
SecondaryNumberUnit
DT_WSTR
255
SecondPostDirection
DT_WSTR
255
SecondPreDirection
DT_WSTR
255
SecondSuffix
DT_WSTR
255
SmallTownDefault
DT_BOOL
0
StandardizedOutputCityStateZip
DT_WSTR
255
StandardizedPrUrbanizationName
DT_WSTR
255
StreetNameChanged
DT_BOOL
0
UniqueZipCodeDefault
DT_BOOL
0
UniqueZipCodeMatch
DT_BOOL
0
UnofficialPostOfficeName
DT_BOOL
0
UnverifiableCityState
DT_BOOL
0
ZipCode4
DT_WSTR
255
ZipCodeAssignedWithMultipleResponse
DT_WSTR
255
ZipCodeCorrected
DT_BOOL
0
ZipMoveMatch
DT_BOOL
0
USPS Database Installation and Updates
Important:  As of January 1, 2019, SentryOne no longer provides subscriptions or updates to the AVDB database.  Customers need to subscribe and receive updates directly through the USPS’s Electronic Product Fulfillment website. You must purchase the 32-bit version because the 64-bit version is not yet supported.
Previous customers that received updates through Pragmatic Works - the last update occurred in November of 2018. Per the USPS, databases must be updated within 105 days of the previous update to maintain access. It's recommended customers update their database as soon as possible through the USPS’s Electronic Product Fulfillment website to ensure they maintain access.
Additional Information: For more information about the pricing and fees for the USPS database subscription, see the following link.
Setting up the USPS Database for Task Factory
Complete the following steps to update your USPS database and assemblies when using the Task Factory Address Verification component:
Step One : Download Assemblies and Database
  1. Log in to the USPS’s Electronic Product Fulfillment website, and then download the following files:
    • AMS Commercial DVD SHA-256
    • AMS Developer Kit SHA-256
    • DPV Developer Kit SHA-256
Task Factory Download USPS Assemblies and Database
Step Two : DPV Extraction
  1. Extract dpv_devkit.tar to the desired directory.
  2. Run the gdev.exe application. Note:  The gdev.exe application is located in the directory where dpv_devkit.tar was extracted.
  3. Select the W32 platform and then select all the files in the Select Files section.
    Task Factory DPV Extraction
  4. Enter your USPS customer id for the W32 customer ID. Note:  You may need to email the USPS support team for this step.
  5. Enter the destination directory. Important:  Ensure you include the \ at the end of the path. For example,  c:\usps\output\ .
    Task Factory W32 Customer ID
  6. Select Extract to proceed with the extraction. Note:  You should receive this message:
    Task Factory DPV Extraction Message
Step Three : AMS Extraction
  1. Extract the ams_devkit.tar file to the desired directory.
  2. Run the gdev.exe application. Note:  The gdev.exe application is located in the directory where ams_devkit.tar was extracted.
    Task Factory AMS Extraction
    Task Factory AMS Extraction Message
  7. Now copy the unencrypted files from both the AMS and DPV directories defined in the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Sentry One\Task Factory\AmsDirectory. Note:  You only need the .dll and .lib files.
    Task Factory AMS Directory
Note:  Now the directory should look like this :
Task Factory Updated Directory example
Step Four : USPS Database Extraction
  1. Extract the contents of dvd_comm.tar to a temp directory.
  2. Rename the following:
    • ams_comm directory to ams
    • ams_dpv directory to dpv
    • ams_elot directory to elot
Note:  Your directory should now look like this :
Task Factory Updated AMS Directory example
3. Copy all of the directories from the temp directory to the directory defined in the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Sentry One\Task Factory\AmsDbDirectory.
Task Factory AmsDbDirectory
Important:  The database expires after 105 days and users MUST update before this deadline to prevent the database from expiring. This is required per the USPS Database guidelines. Once the database has expired after the 105 day deadline, users have to contact the USPS vendor.
Understanding the USPS Address Verification Output
There are three outputs that are provided by the Address Verification Transform:
  1. Verified Address Output – This output includes all addresses that are returned from the USPS database as either a ResponseCode of 31 (single address found) or 32 (address found, but more accurate address could be located). See response status table for full descriptions.
  2. Invalid Address Output  – This output includes all addresses that are returned from the USPS database with a response code of anything other than 31 or 32 .
  3. Multiple Address Output – This output includes the other addresses found when an address is returned with a status of 22 (multiple addresses found). The address record with a status of 22 sends out of the Invalid Address Output if the Unverified Address Behavior is set to Redirect unverified to unverified output in the:
    Task Factory Unverified Address Behavior Example
  4. Error Output – This output contains any addresses where the data from the input column mapped to the Address 1 Source Column contains an empty or null value.
Output Columns
Verified Address Output Column Definitions
Column Name Definition
AddressLine1
The standardized address line1 from the USPS database.
AddressLine2
The standardized address line2 from the USPS database.
City
The standardized city from the USPS database.
State
The standardized state from the USPS database.
ZipCode
The standardized zip code from the USPS database.
ResponseCode
The response code returned from the USPS database. See Response Code Table for the codes and definitions.
AbbreviatedCity
The abbreviated city.
An address component (i.e., directional or suffix only) was added, changed, or deleted in order to achieve a match.
AddressKey
Internal address database key (for indexing).
AddressNotFound
Set to true if the address wasn’t found.
AddressStandardized
Set to true if the address was standardized. For example, if STREET was in the delivery address, the system returns ST as its standard spelling.
Set to true if information in the firm line was determined to be a part of the address. It was moved out of the firm line and incorporated into the address line.
BetterAddressExists
Set to true if the delivery address can be matched, but is known by another (preferred) name. For example, in New York, NY, AVENUE OF THE AMERICAS is also known as 6TH AVE. An inquiry using a delivery address of 55 AVE OF THE AMERICAS would set this value to true.
CarrierRoute
The USPS 4 digit carrier rate code.
Set to A, B, C, or D :
  • A = CR Sort Rates Apply Merge Allowed
  • B = CR Sort Rates Apply Merge Not Allowed
  • C = CR Sort Rates Do Not Apply Merge Allowed
  • D = CR Sort Rates Do Not Apply Merge Not Allowed
CityStateCorrected
The spelling of the city name and/or state abbreviation in the submitted address was found to be different than the standard spelling. The standard spelling of the city name and state abbreviation are shown in the output address.
CountyCode
The USPS county code for the address.
DeliveryPoint
The USPS delivery point for the address.
FirmName
The standardized firm name.
FirstPostDirection
First or Left Post-direction.
FirstPreDirection
First or Left Pre-direction.
FirstSuffix
First or Left Suffix.
Set to true if the secondary number was incorrect.
Set to true if Insufficient / Incorrect data is found.
InvalidCityStateZip
Set to true if an invalid city, state and zip was found.
LookupStatus
The return code value returned from the USPS database.
The city of the main post office for the standardized address.
The state of the main post office for the standardized address.
The primary address number.
The primary secondary number.
MilitaryMatch
Set to true if a match was made with a military zip code.
Set to true if ZIP+4 information indicates this address is a building. The address as submitted does not contain an apartment/suite number. It is recommended that the requestor check the submitted address and add the missing apartment or suite number to ensure the correct Delivery Point Barcode (DPBC).
More than one ZIP+4 Code was found to satisfy the address as submitted. The lowest ZIP +4 add-on may be used to break the tie between the records.
The search resulted in a single response; however, the record matched was flagged as having magnet street syndrome. “Whenever an input address has a single suffix word or a single directional word as the street name, or whenever the ZIP+4 File records being matched to have a single suffix word or a single directional word as the street name field, then an exact match between the street, suffix and/or post-directional and the same components on the ZIP+4 File must occur before a match can be made. Adding, changing or deleting a component from the input address to obtain a match to a ZIP+4 record will be considered incorrect.” Instead of returning a no match in this situation a multiple response is returned to allow access the candidate record.
NoMatchDueToEws
Set to true if the delivery address can be matched, but the EWS file indicates that an exact match will be available soon.
NonPoBoxDualAddress
CASS rule does not allow a match when the cardinal point of a directional changes more than 90%.
NoZip4Assigned
The ZIP Code in the submitted address could not be found because neither a valid city, state, nor valid 5-digit ZIP Code was present. It is also recommended that the requestor check the submitted address for accuracy.
PoBoxDualAddress
Set to true if the input contained two addresses. For example: 123 MAIN ST PO BOX 99.
PrimaryName
The primary street name.
PrimaryNumber
The primary street number.
RuralRouteNumber
The rural route number.
SecondaryNumber
The secondary number of the street address.
SecondaryNumberUnit
The secondary number unit of the street address.
SecondPostDirection
Second or Right Post-direction.
SecondPreDirection
Second or Right Pre-direction.
SecondSuffix
Second or Right Suffix.
SmallTownDefault
Set to true because of an invalid delivery address. The input address record contains a delivery address other than a PO BOX, General Delivery, or Postmaster with a 5-digit ZIP Code that is identified as a “small town default.” The United States Postal Service does not provide street delivery for this ZIP Code. The United States Postal Service requires use of a PO BOX, General Delivery, or Postmaster for delivery within this ZIP Code.
The standardized city, state and zipcode.
The standardized Puerto Rico urbanization.
StreetNameChanged
Set to true if the standardized address changed the street name.
Set to true if a default match inside a unique ZIP Code.
UniqueZipCodeMatch
Set to true if an address with a unique ZIP Code was found.
Set to true if the city or post office name in the submitted address is not recognized by the United States Postal Service as an official last line name (preferred city name), and is not acceptable as an alternate name. This does denote an error and the preferred city name will be provided as output.
Set to true if the city and state in the submitted address could not be verified as corresponding to the given 5-digit ZIP Code. This comment does not necessarily denote an error; however, it is recommended that the requestor check the city and state in the submitted address for accuracy.
ZipCode4
The last 4 digits of the standardized address zip code.
Set to true if multiple records were returned, but each shares the same 5-digit ZIP Code.
ZipCodeCorrected
Set to true if the zip code was corrected when the address was standardized.
ZipMoveMatch
Set to true if the ZIPMOVE product shows which ZIP + 4 records have moved from one ZIP Code to another. If an input address matches to a ZIP + 4 record which the ZIPMOVE product indicates as having moved, the search is performed again in the new ZIP Code.
Unverified Address Output
This output contains all the input column data along with a column named WhyInvalid which tells you why the address was deemed invalid by the USPS database.
Error Output
This output contains all the input column data along with a column named ErrorDescription which tells you input data was deemed invalid by the address verification transform.
Column Name Description
ActionCode
A field indicating the action to be taken in updating the base master files.
AddOnHigh
The high-end ZIP add-on in a range of codes; the add-on of the last +4 code in a consecutive series of +4 codes assigned to the delivery address. Most delivery addresses are assigned a single +4 code; however, large companies may be given a range of +4 codes that can be used to route mail to specific departments. A range of +4 codes can also be assigned to a corresponding range of Post Office boxes, and each box is mapped, one-to-one, with a +4 code in the range. A single Post Office box can also be assigned a range of +4 codes. (See +4 Code.)
Example:
12345-0001 through 12345-0009 => +4 High Number = 0009+4 codes associated with non-delivery areas are composed of valid ZIP™ sector numbers and “ND” for the ZIP segment number. Non-deliverable areas are areas to which the USPS does not deliver mail, such as vacant lots and land that borders railroad tracks. Mailers should not match an address identified as a non-delivery area. (See ZIP Sector Number or ZIP Segment Number.)
AddOnLow
The last four positions of a +4 code; the low-end +4 in a range of codes; the add-on of the first +4 code in a consecutive series of +4 codes assigned to the delivery address. For example, most delivery addresses are assigned a single +4 code. However, large companies may be given a range of +4 codes that can be used to route mail to specific departments. A range of +4 codes can also be assigned to a corresponding range of Post Office boxes, and each box is mapped, one-to-one, with a +4 code in the range. A single post office box can also be assigned a range of +4 codes.
Example:
12345-0001 through 12345-0009 => +4 Low Number = 0001+4 Codes associated with non-delivery areas are composed of valid ZIP sector numbers and “ND” for the ZIP segment number. Non-deliverable areas are areas to which the USPS does not deliver mail, such as vacant lots and land that borders railroad tracks. Mailers should not match an address identified as a non-delivery area. (See ZIP Sector Number or ZIP Segment Number.)
BaseAlternateCode
Code that specifies whether a record is a base (preferred) or alternate record. Base records (represented as B) can represent a range of addresses or an individual address, such as a firm record, while alternate records (represented as A) are individual delivery points.
Base Data Element Definitions Address Information System Products Technical Guide 62 records are generally preferred over alternate records. However, one exception is ZIP+4® product; in this file, government deliveries will only be listed on alternate records with the appropriate government building indicator (federal, state, or city) set.
CarrierRoute
A 4-byte code assigned to a mail delivery or collection route within a 5-digit ZIP™ Code. The first character of this identification is alphabetical, and the last three are numeric:
  • B### = PO box
  • H### = Contract
  • R### = Rural route
  • C### = City delivery
  • G### = General delivery
CongressionalDistrict
A standard value identifying a geographic area within the United States served by a member of the U.S. House of Representatives. If Army/Air Force (APO), Fleet Post Office (FPO), or Diplomatic/Defense Post Office (DPO), this field will be blank. If there is only one member of Congress within a state, the code will be AL (at large).
CopyrightDetailCode
Alphabetic code that identifies the type of record in a USPS® product file.
  • A = Alias record
  • C = Copyright record
  • D = Detail record
  • N = Seasonal record
  • S = 5-Digit ZIP scheme combinations record
  • Z = Zone split record
CountyNumber
The Federal Information Processing Standard (FIPS) code assigned to a given county or parish within a state. In Alaska, it identifies a region within the state. If APO/FPO/DPO, and the record type is S, H, or F, the county number will be blank.
FinanceCode
A code assigned to Postal Service™ facilities (primarily Post Offices) to collect cost and statistical data and compile revenue and expense data.
FirmOrBuildingName
The firm or building name.
LACSConvertedStatus
The Locatable Address Conversion Service (LACS) indicator describes records that have been converted to the LACS system (a product/system in a different USPS® product line that allows mailers to identify and convert a rural route address to a city-style address). Rural route and some city addresses are being modified to city-style addresses so that emergency services (e.g., ambulances, police) can find these addresses more efficiently.
  • L = LACS address: The old (usually rural-route) address that has been converted for the LACS system.
  • Blank = Not applicable
LastLine
A value that uniquely identifies a city state name in the City State product.
PostDirection
A geographic direction that follows the street name.
Example:
123 MAIN ST N Street Post-Directional Abbreviation = N Spaces = No post-direction E = East N = North NE = Northeast NW = Northwest S = South SE = Southeast SW = Southwest W = West
PreDirection
A geographic direction that precedes the street name.
Example: 123 N MAIN ST Street Pre-Directional Abbreviation = N Spaces = No pre-direction E = East N = North NE = Northeast NW = Northwest Data Element Definitions Address Information System Products Technical Guide 76 S = South SE = Southeast SW = Southwest W = West
PrimaryEvenOddCode
The address primary even/odd code.
  • O = Odd
  • E = Even
  • B = Both
PrimaryHighRange
A house, rural route, contract box, or Post Office box number. The numeric or alphanumeric component of an address preceding the street name. The high-end address in a range of addresses. Often referred to as house number.
Examples:
Address Range Primary High Number
100 – 198 Main Ave
198
101 – 199 Main Ave 199
199
A200 – A298 Main Ave A298
A298
124-45 – 124-88 Main Ave
124-88
101 – 120 PO Box
120
22A – 22B RR 2
22B
PrimaryLowRange
A house, rural route, contract box, or Post Office box number. The numeric or alphanumeric component of an address preceding the street name. The low-end address in a range of addresses. Often referred to as house number
Examples:
100 – 198 Main Ave
100
101
A200
124-45
101 – 120 PO Box
101
22A – 22B RR 2
22A
RecordType
The record type.
  • G = General delivery
  • M = Multi-carrier
  • P = PO Box
  • R = Rural Route
  • S = Street
SecondaryEvenOddCode
The address secondary even/odd code.
  • O = Odd
  • E = Even
  • B = Both
SecondaryHighRange
Code that describes an apartment, room, suite, space, floor, or other secondary addressing numeric or alphanumeric that follows a street address. The high-end secondary address component in a range of secondary addresses.
Examples:
Address Range Address Secondary High Number
00000001 through 00000009
00000009
A through F
F
66A through 66E
66E
SecondaryLowRange
Code that describes an apartment, room, suite, space, floor, or other secondary addressing numeric or alphanumeric that follows a street address. The low-end secondary address component in a range of secondary addresses.
Examples:
0000000A
A through F
A
66A through 66E
66A
SecondaryUnit
A descriptive code used to identify the type of address secondary range information in the Address Secondary Range field. This code may be useful in address matching, e.g., the secondary address numbers may indicate apartment, suite, or trailer numbers. (See Publication 28, Postal Addressing Standards, for values.)
StreetName
The official name of a street as assigned by a local governing authority. The Street Name field contains only the street name and does not include directionals (EAST, WEST, etc.) or suffixes (ST, DR, BLVD, etc.). This element may also contain literals, such as PO BOX, GENERAL DELIVERY, USS, PSC, or UNIT. Numeric street names that have numeric components that are four characters (or less) in length at are justified such that the low-order digit of the number is positioned in the fourth position of the street name field. This shift is made so that the numeric street names appear in numeric sequence.
Suffix
Code that is the standard USPS® abbreviation for the trailing designator in a street address. (See Publication 28, Postal Addressing Standards, for values.)
UpdateKeyNumber
Field that contains a number that uniquely identifies a record; used to identify the base record to which an add or delete transaction is being directed. The Update Key Number field is used only when applying transactions to the base file; it is not used in address matching and remains fixed for the life of the record. The field is alphanumeric and consists of the database segment code (V1, V2, W1, W2, X1, X2, Y1, Y2, Z1, or Z2) and eight characters containing an alphanumeric value ranging from 00000001 to AAAAAAAA.
Urbanization
An index to the City State file that provides the urbanization name for this delivery range.
ZipCode
A 5-digit code that identifies a specific geographic delivery area. ZIP Codes can represent an area within a state, or a single building or company that has a very high mail volume.
Response Status Table
Response Code Definition
10
The address was sent to the verification database was invalid (i.e. contained a dual address)
11
The address supplied had an invalid zip code
12
The address supplied had an invalid state abbreviation code
13
The address supplied had an invalid city name
