Task Factory Regex Replace Transform
RegEx Replace Transform
| Transform Icon | Transform Description |
The RegEx Replace Transform allows the user to replace or extract data from a source column using regular expressions. |
Input Columns
| Option | Description |
| Input Columns | Columns from your source input. |
| Choose Action | The RegEx Replace Transform has two actions that can be used to either replace or extract data from a source column.
Additional Information: See the Task Factory Error Row Handling article for more information about this functionality.
