Events in Server Configuration Monitor (SCM)
You can view events in the SolarWinds Platform Web Console Message Center, found under Alerts & Activity, and in several widgets throughout the SolarWinds Platform Web Console. Server Configuration Monitor (SCM) fires the following events:
| Event text | Description |
| Server configuration baseline set to <datetime> on node '<node>' | The baseline has been set for the first time on a node. |
| Server configuration baseline reset to <datetime> on node '<node>' | The baseline has been set to a different datetime. |
| Server configuration differs from baseline on node '<node>' | Server's configuration has changed and no longer matches the baseline. |
| Server configuration matches the baseline on node '<node>' | Server's configuration that didn't match the baseline before has changed to match it. |
