See detected candidates for configuration monitoring in Server Configuration Monitor (SCM)
SCM will automatically detect servers that have been added to the Orion Platform that might be eligible for monitoring one or more of the out-of-the-box profiles. You can view a list of candidate servers on the SCM Summary page, which can be found under My Dashboards.
The Candidates for Server Configuration Monitoring widget lists servers that might be eligible for configuration monitoring but do not have an agent, and servers that are eligible for monitoring each out-of-the-box profile. From there, you can push agents or assign the suggested profiles using the links provided. The Dismiss all link will stop those nodes from being suggested again.
Whether a node is eligible for configuration monitoring is determined in the following ways:
Suggested action | Eligibility requirements |
Push an agent |
Any node running Windows Server 2008 R2 SP1 or later OR Any node running Linux kernel 2.6.23 or later |
Assign HW/SW inventory profiles | Any node with AssetInventory enabled |
Assign an out-of-the-box profile | If the node is monitored by a respective SAM application, it's a candidate for SCM monitoring by a specific profile. For example, any node monitored by AppInsight for IIS, or another SAM app template tagged as 'IIS' is a candidate for SCM monitoring by IIS configuration profile. |
