Get Started with Enterprise Operations Console
The purpose of this guide is to help you get started with Enterprise Operations Console (EOC) through the initial setup. EOC provides a consolidated view of status and performance data from your distributed SolarWinds Platform instances. If you are interested in evaluating SolarWinds EOC, you can download a fully-functional 30 day trial.
SolarWinds provides customers access to SolarWinds Smart Start implementation experts who assist you in installing and configuring your product.
Who should use this guide?
| New EOC Users | Existing EOC Users |
| This guide continues from the installation of EOC and takes you through initial configuration. |
Users already familiar with EOC can find advanced information and guidance in the EOC Administrator Guide. For information on upgrading to the latest version of EOC, see EOC Installation and Upgrade Guide. |
Topics covered
This document guides you through the following tasks to get started with SolarWinds EOC:
Log in to EOC If you have not installed EOC yet, see SolarWinds Installer for EOC for system requirements, planning checklists, troubleshooting, and installation instructions. |
Add a SolarWinds Site to EOC Using the Add Sites Wizard, SolarWinds EOC can connect to any SolarWinds Site that runs on a supported version of the SolarWinds Platform (or Orion Platform). |
Add EOC user credentials Specify which SolarWinds Site a user account can access, and associate each EOC user account with a SolarWinds Site account to view site data. |
Learn about EOC dashboards Learn about the different EOC dashboards, such as EOC Summary and EOC Maps, used to view and manage data from SolarWinds Sites. |
Import SolarWinds Site maps into EOC
Understand the difference between the Network Atlas and Worldwide maps and how to import, place, and display maps from SolarWinds Sites in EOC. |
Use All Alerts to view status information and alerts Learn how to view site status information to respond to triggered events, and how to quickly display alert information most important to you. |
Create SolarWinds Site reports in EOC |
Beyond getting started with EOC Learn about additional resources available to you as you expand your use of EOC. |
