Run external diagnostic tools on map nodes
To help you diagnose problems with your network, you can run external tools on any of the nodes visible in your map.
Run Windows Ping, Remote Desktop, Telnet, or Traceroute
- Right-click any node.
- Select Integration with Windows Tools.
- Remote Desktop
- Traceroute
- Ping
- Telnet
You can run:
Run SolarWinds Engineer's Toolset Tools
- Select Integration with Engineer's Toolset.
If you have SolarWinds Engineer's Toolset v10.9 or later installed, you can run:
- Traceroute
- Enhanced Ping
- Lookup IP Address
- Lookup Hostname
- CPU Gauge
- Switchport Mapper
