Documentation forNetwork Topology Mapper
Import maps
NTM allows you to import Network Atlas maps. For more information about Network Atlas, see the sections on Network Atlas in the SolarWinds Platform (self-hosted) help.
Import a map
  1. Click File > Import > Network Atlas Maps.
  2. Create a file password as needed.
  3. Navigate to a saved Network Atlas map and click Open.
Save a map
  1. Click File > Save as.
  2. Navigate to the folder you want to save map files in, enter a File Name, and then click Save.
Open a saved map
  1. Click File > Open.
  2. Navigate to the folder containing the map, and then click Open.
Use map backgrounds
Map backgrounds allow you to arrange nodes in NTM to the fit layout of your network. Backgrounds should show network locations and not include Network nodes or connections. NTM nodes and connections overlay backgrounds. You have two sample map backgrounds available in NTM. These backgrounds are meant to demonstrate how map backgrounds look. They are not specific to any actual network.
  • Map background files must be gif, jpeg, jpg, or PNG format.
  • For best fit and resolution files should be 1600 X 1024 at 72 DPI.
  • Background files are stored in \Documents and Settings\{user_name}\My Documents\My Pictures\Network Topology Mapper Backgrounds.
Import and apply a new map background file or apply an existing background
  1. Click Edit > Background picture import….
  2. Navigate to your background map, and then click Open.
To remove a background from a map click Edit > Remove background.
