Documentation forNetwork Topology Mapper
NTM requirements
SolarWinds strongly recommends that you install Network Topology Mapper on a server that is neither public, nor internet-facing. To learn about best practices for configuring your Network Topology Mapper installation securely, see Best practices to secure SolarWinds Products.
The following tables provide the minimum requirements for SolarWinds NTM.
Hardware/
Software
Requirements
Operating System
  • Microsoft Windows 10 and 11
  • Microsoft Windows Server 2016
  • Microsoft Windows Server 2019
  • Microsoft Windows Server 2022
  • Microsoft Windows Server 2025
NTM supports FIPS.
Languages:
  • English
  • German
  • Japanese
  • Chinese
CPU Speed
2.66 GHz or faster
Device discovery and map rendering are CPU-intensive. SolarWinds recommends installing NTM on the fastest CPU PC available.
Hard Drive Space
10 GB
Memory
500 MB
Application Framework
.NET 3.5 SP1
.NET 4.8
If .NET is missing, install .NET Framework 4.8. See Microsoft .NET Framework 4.8.
Port requirements
Port Protocol Service or process Direction Description
161 UDP SolarWinds Network Topology Job Scheduler Outbound The port used for SNMP statistics collection.
443 TCP SolarWinds Network Topology Job Scheduler Bidirectional
The port used to communicate with VMware Virtual Center or ESX server.
17778 HTTPS SolarWinds Network Topology Job Scheduler Outbound The port used to access the SolarWinds Information Service (SWIS) API for exporting maps from a scheduled discovery to Network Atlas.
135 and a range between 1024 and 65535 TCP/UDP SolarWinds Network Topology Job Scheduler Bidirectional
WMI uses TCP Port 135 and a range of dynamic ports between 1024 and 65535. You can set up WMI to use a custom range. For details, see Setting Up a Fixed Port for WMI in Microsoft documentation (© 2023 Microsoft, available at https://learn.microsoft.com/en-us/windows/win32/wmisdk/setting-up-a-fixed-port-for-wmi, obtained on May 22, 2023.)
