Icons and Labels
SolarWinds NTM represents devices on maps with these icons:
| Icon | Explanation |
EnergyWise device |
Firewall |
Hyper-V Guest |
Hyper-V Host |
ICMP Node |
L3/L2 Switch |
Network Segment Node |
Printer |
Router |
Router Wireless AP |
EnergyWise Device |
Switch |
VMWare Datacenter |
VMWare Guest |
VMWare Host |
VOIP Phone |
Wireless AP |
Wireless Controller |
WMI Node |
Shadow Node |
SNMP Node |
Additionally, you can use custom icons on your computer to represent any node.
Adjust the icon for a node
- Right-click a node and select Custom Icon.
- Select the relevant Node Role.
- If you want to use a custom icon for the node role, click Browse and locate the desired image file on your computer.
- Click the Machine Types tab.
- If you want to use a custom icon for the machine type, click Browse and locate the desired image file on your computer.
- Click OK.
- To resize the icon, right-click, select Icon Size > Small/Medium/Large/Default.
Adjust the label for a node
Click the label and drag to relocate. Alternately, right-click the label, select Place Text and the desired option.
