Exclude devices from a scan
After you have defined subnets, IP address ranges, and other hostnames and IP addresses in which to discovery devices, exclude any devices (if any) from the ranges and subnets.
- Click the Do-Not-Scan List tab and do one of the following:
- If you are excluding individual hostnames or IP addresses, type the each one on its own line.
- If you are excluding a range within a subnet, type each range on its own line.
In specifying a range of devices within a subnet, you can use format that delimits addresses with a hyphen (for example,
10.0.0.10-10.0.0.42 or 2001:db8:0:0:0:0:0:0-2001:db8:0:ffff:ffff:ffff:ffff:ffff) or CIDR notation (for example,10.0.0.0/24or2001:db8::/48). - When you are finished defining exclusions, click Next.
