Plan what should be on a view/classic dashboard in the SolarWinds Platform
This topic applies to all SolarWinds Platform products.
Plan what should be on a view before you create it or before you start customizing it.
Before you create a view/classic dashboard
| Option | Action | |
Identify objects to see on the view/dashboard. | Select the appropriate object type, such as nodes, interfaces, groups, applications, and so on. |
View information for all objects of the selected object type. | Select a Summary view. |
View details for a selected object. | Select a Details view. |
Customize what the view/classic dashboard displays
| Option | Action | |
Specify information about the objects you want to see. | Add widgets that display metrics you want to see. |
Divide the information into several tabs. | Create tabs and specify widgets for each tab. |
Optimize the view/classic dashboard for large screens or mobile devices. | Create a Network Operations Center (NOC) view. |
Limit what devices should be displayed. | Add a limitation. |
Access the view from My Dashboards. | Add the view/dashboard into a menu bar and make sure the menu bar is available for users you are targeting. |
View entities on a map. |
Decide what kind of map to use.
