Configure an approval process
An approval process contains at least one step, and each step is approved by a client, a CAB, a location approver, or a department approver.
In the following example, a one-step approval process is created, the IT Department Approver is assigned as the approver, and the IT General/Other > Upgrade Request type is associated with the process.
- Click Setup > Processes > Approval Processes.
Click New.
Enter a name for the process and click Save.
Click Approval Steps, and then click New.
- Enter a name for the approval step.
- Click an approver type. For example, Department Approver.
Select the approver to assign to the step.
- Enter the email text that will be sent to request approval for a ticket.
- Click Save.
- If necessary, add additional approval steps.
- When you have added all steps, click Request Types Supported.
Click Edit.
Select all request types to associate with this approval process, and click Save.
- On the Request Types Supported tab, click Done.
