Documentation forVirtualization Manager
Start monitoring virtual systems in VMAN
With VMAN, you can monitor VMware vCenter servers and ESX hosts, and HyperV hosts. You can also monitor AWS cloud instances and volumes, which is covered in the VMAN Admin Guide. This guide shows you how to add a vCenter server or HyperV host to monitor in VMAN.
See Supported versions of VMware, Hyper-V, and Windows Server for monitoring to confirm which versions of vCenter Server and Hyper-V or Windows Server are supported in VMAN.
After you're logged into the Orion Web Console, it's easy to start adding VMware vCenters and HyperV hosts.
