- Release Notes
- IPAM 2025.1.1 release notes
- IPAM 2025.1 release notes
- IPAM 2024.4.1 release notes
- IPAM 2024.4 release notes
- IPAM 2024.2.1 release notes
- IPAM 2024.2 release notes
- IPAM 2024.1.1 release notes
- IPAM 2024.1 release notes
- IPAM 2023.4.2 release notes
- IPAM 2023.4.1 release notes
- IPAM 2023.4 release notes
- IPAM 2023.3.1 release notes
- IPAM 2023.3 release notes
- IPAM 2023.2.2 release notes
- IPAM 2023.2.1 release notes
- IPAM 2023.2 release notes
- IPAM 2023.1.1 release notes
- IPAM 2023.1 release notes
- IPAM 2022.4.1 release notes
- IPAM 2022.4 release notes
- IPAM Hotfixes
- IPAM release history
- Install or Upgrade
- IPAM Installation and Upgrade Guide
- IPAM licensing and deployment
- Install or upgrade IP Address Manager
- SolarWinds Platform Products Installation and Upgrade Guide
- Scalability Engine Guidelines for SolarWinds products
- SolarWinds Platform Migration Guide
- Deploy SolarWinds Platform products to Amazon Web Services
- Deploy SolarWinds Platform products to Microsoft Azure
- Install SolarWinds Platform products using Azure Marketplace
- Get Started
- Administer
- IPAM Administrator Guide
- IPAM Introduction
- How IPAM works
- IPAM concepts and terminology
- Configure IPAM
- Define system settings for IPAM
- Configure subnet scan settings manually
- The IPAM Scan Job Status page
- Neighbor scanning in IPAM
- Populate UDT User and Switch Ports in the IPAM IP Address View
- Manage credentials
- User role delegation in IPAM
- Custom properties
- IPAM groups
- Add Additional Polling Engines to IPAM
- Display or change polling engine assignments in IPAM
- Add IP addresses to IPAM
- Manage Subnets and IP Addresses page
- Manage IP addresses
- Search for IP addresses in IPAM
- Edit IP Address page
- Set an IP address status to Available, Used, Transient, or Reserved in IPAM
- Create a range of IP addresses in a subnet
- Organize an IP address space into IPAM subnets
- IP address conflicts
- Remove monitored IP addresses from a subnet
- Overlapping IP addresses and hierarchy groups in IPAM
- Adding IPv6 addresses to IPAM
- IP address requests
- Manage subnets in IPAM
- Manage supernets in IPAM
- DHCP and DNS Management views
- Monitor and manage DHCP servers
- Monitor and Manage DNS servers in IPAM
- Monitor the Infoblox environment
- Integrate IPAM with VMware
- Amazon Route 53 and Azure DNS monitoring
- Use the SWIS API to perform IPAM operations
- IPAM status icons
Add IP Address Range
Enter the first and last IP address to be added to the subnet. The range must be within the subnet range, as displayed in the Parent Address field.
