Administer > Monitor database instances with DPA > DPA troubleshooting tips
Logs
DPA logs information about each monitored database instance. Use this information to help you determine why a database instance is not being monitored, or if data are missing.
Access log data through the DPA log viewer
Use the DPA Log Viewer to view log information for a specific database instance, or for all database instances and the DPA repository.
  1. Open the Log Viewer:
    • To display log messages for a specific database instance:
      From the DPA homepage, click Action > Log next to the database instance.
    • To display messages for all monitored database instances and the DPA repository:
      In the DPA menu bar, click Options. Then, under Support > Utilities, click Log Viewer.
  2. Use any of the following options to locate information:
    • Use filters to help you find specific information. To change the filters, click Advanced and select the filter criteria. For example, you can filter by date range, a text string, or message level.
    • For any message above Info, click Details to view additional information from the log.
    • Click Log Files for Support to create a compressed file you can send to SolarWinds Support.
Open log files in a text editor
Log files are stored in the installDir/iwc/tomcat/logs/ directory.
Access to a database instance
If DPA cannot access the server that hosts a database instance you want to monitor:
  • Make sure a firewall is not running on the server.
  • Make sure another process is not using the default DPA ports.
If the ports are being used by another process, you can change the default ports of 8123, 8124, and 8127. To specify different ports for DPA to use:
  1. Open the following file in a text editor:
    installDir/iwc/tomcat/conf/server.xml
  2. Update the following lines with new port numbers:
    <Server port="8127" shutdown="SHUTDOWN">
        <Connector port="8123"/>
        <Connector port="8124"/>
  3. Save the file and restart DPA.
Issues after the Oracle PDB that stores the repository is moved
If the DPA repository is created on an Oracle pluggable database (PDB), you might experience the following issues after the PDB is moved to a different container database (CDB).
DPA returns a connection error
The PBD moved to a CDB on a different server, and the connection string is incorrect. Update the connection string in the repo.properties file in the following location:
<DPA_Install_Dir>\iwc\tomcat\ignite_config\iwc\repo.properties
DPA returns an invalid login error
Verify that the DPA monitoring user exists in the CDB. Common users (prefaced with C##) exist in only one CDB.
