Register an Amazon RDS for Oracle database
To register an Amazon RDS for Oracle database for DPA to monitor:
- On the DPA homepage, click Register DB Instance for Monitoring.
- Under Amazon RDS, click Amazon RDS for Oracle.
- Click Next.
- Complete the wizard panels as described in the following table.
If registration fails because your DPA server cannot connect to the instance's server, see DPA database registration failure when attempting to register a database on an external network.
| Panel | Instructions |
| Enter Monitored Database Instance Connection Information |
Amazon Relational Database Service (RDS) for Oracle database instances have three connection options:
Direct ConnectEnter the Service Name or System Identifier (SID), host name or IP address, and port. The default port is 1521. TNS Connect DescriptorThe Connect Descriptor value contains everything after
LDAP or TNS NameTo use this option, Oracle Name Resolution must be configured. For instructions, see Connect to Oracle using name resolution. After you configure Oracle Name Resolution, you can use the LDAP/TNS Name when registering additional monitored database instances. RAC instancesIf this is an Oracle Real Application Clusters (RAC) instance, there may be listener configuration changes needed if you are not listening on the physical IP address. SolarWinds recommends:
DBA userEnter DBA credentials for DPA to register the database instance. |
| Enter the Monitoring User |
Create or specify the account that DPA will use to gather information. To ensure that the account has the required permissions, SolarWinds recommends creating a new account. To create a new account:
To specify an existing account:
If you create the user manually, DPA uses the default Tablespaces for that user. |
| Oracle Monitoring Information |
If the monitored instance contains the Oracle E-Business Suite, DPA can collect additional information about the suite. DPA can capture Oracle E-Business data to identify the screens, modules, and users generating the database requests. This gives you increased visibility into the causes of performance problems in the Oracle E-Business Suite, Oracle Enterprise Resource Planning (ERP), and Oracle Applications environments. The SYS password option is not available for Amazon RDS instances. |
| Oracle Repository Tablespace |
If your repository database is not Oracle, the wizard skips this step. Choose the tablespace in the repository database to store DPA performance data for this monitored instance. By default, the performance data is stored in the default tablespace of the repository user. However, data for monitored instances can be stored in separate tablespaces. |
| Select the Alert Groups |
If you have no Alert Groups set up, or if this new database instance does not match the database type of the Alert Group, the wizard skips this step. Alert Groups simplify alert configuration and help make alerting more consistent across the monitored database instances. Select the Alert Groups you want the new database instance to join. |
| Summary | Review the information and click Register Database Instance. |
| Database Instance Registration Complete | Click Finish to return to the DPA homepage. |
If you register a database instance within the 14-day trial period, DPA begins monitoring the instance immediately. After the trial period, you must activate a license to monitor the database instance.
