Administer > Register a database instance for monitoring with DPA > Register an Azure SQL database
To register multiple Azure SQL databases using the Mass Registration feature, follow the instructions in this KB article.
To register a single Azure SQL database for DPA to monitor:
  1. On the DPA homepage, click Register DB Instance for Monitoring.
  2. Under Azure, click Azure SQL DB.
  3. Click Next.
  4. Complete the wizard panels as described in the following table.
Panel Instructions
Enter Monitored Database Instance Connection Information
Enter the server name, port, and database name. You cannot use an IP address in the Server Name field.
Choose a method for creating or configuring the monitoring user.
To create a new account:
  1. Click Let DPA create a new contained user or configure an existing contained user for me.
  2. Enter the credentials of an existing user with privileges to create the monitoring user and to grant the required permissions.
    The privileged user must be a member of the db_owner role.
    The credentials for the privileged user are not used or stored after the registration.
To specify an existing account:
  1. Click I'll create the database user.
  2. Enter credentials. DPA encrypts the password.
Alternatively, you can use the script that DPA provides to create a monitoring user.
  1. Click Monitoring User Creation Script, and follow the on-screen instructions.
  2. Copy and run the edited script on your Azure SQL database.
  3. Provide this user as your monitoring user.
Enter the Monitoring User
DPA gathers information through this user from the monitored database. You can create a monitoring user through DPA or use an existing user, such as for read-only replica databases.
To register a read-only geo-replica, you must create a monitoring account through the primary server first.
SolarWinds recommends creating a new account because DPA requires special permissions that existing users may not have.
  1. Click Let DPA create a new contained user.
  1. Run the following SQL statement on the Azure SQL database:
    CREATE USER [<USERNAME>] WITH PASSWORD=N'<PASSWORD>';
    ALTER ROLE db_owner ADD member <USERNAME>;
  2. Click Let DPA configure an existing contained user.
  3. Enter credentials.
Oracle Repository Tablespace
If your repository database is not Oracle, the wizard skips this step.
Choose the tablespace in the repository database to store DPA performance data for this monitored instance.
By default, the performance data is stored in the default tablespace of the repository user. However, data for monitored instances can be stored in separate tablespaces.
Select the Alert Groups
If you have no Alert Groups set up, or if this new database instance does not match the database type of the Alert Group, the wizard skips this step.
Alert Groups simplify alert configuration and help make alerting more consistent across the monitored database instances.
Select the Alert Groups you want the new database instance to join.
Summary Review the information and click Register Database Instance.
Database Instance Registration Complete Click Finish to return to the DPA homepage.
Enable deadlocks for read-only geo-replicas
To enable the deadlock feature for read-only geo-replica Azure SQL databases, you must create and enable an Extended Event Session (EES).
If you registered the primary server first, an EES is already created and synced. Skip to step 2.
Otherwise, connect to the primary server first to create an EES.
  1. Run the following SQL statement:
    CREATE EVENT SESSION [dpa_deadlock_capture] ON DATABASE
    ADD EVENT sqlserver.xml_deadlock_report
    ADD TARGET package0.ring_buffer(SET max_events_limit=(1000),
      max_memory=(256))
    WITH (MAX_MEMORY = 256KB,
    EVENT_RETENTION_MODE = ALLOW_SINGLE_EVENT_LOSS,
    MAX_DISPATCH_LATENCY = 30 SECONDS,
    MAX_EVENT_SIZE = 0KB,
    MEMORY_PARTITION_MODE = NONE,
    TRACK_CAUSALITY = OFF,
    STARTUP_STATE = ON);
    -- ALTER EVENT SESSION [dpa_deadlock_capture] ON DATABASE STATE = START;
  2. Connect to the read-only replica database.
  3. Click Extended Events > Sessions.
  4. Enable the dpa_deadlock_capture session.
If you register a database instance within the 14-day trial period, DPA begins monitoring the instance immediately. After the trial period, you must activate a license to monitor the database instance.
