RELEASE NOTES
GET STARTED
How do I get started with DPA?
Register database instances
Register a single SQL Server database instance
Register a virtual machine and view performance data
Examples of investigating performance issues with DPA
The DPA approach to investigating performance issues
Investigate an application performance problem with DPA
Investigate an increase in wait time with DPA
Investigate a wait time anomaly with DPA
Create a DPA alert to monitor SQL statement execution time
Create a DPA report to track wait types for a single SQL statement
After evaluation, activate DPA licenses
Integrate DPA with the Orion Platform
Beyond Getting Started with DPA
Install or Upgrade
DPA installation overview
DPA installation preflight checklist
DPA system and monitoring requirements
DPA system requirements
Database versions you can monitor
Requirements for monitoring MySQL database instances
Install DPA
Install DPA on Windows
Install DPA on Linux
Install DPA on Azure Marketplace
Create the repository database
Create a SQL Server repository database
Create an Oracle repository database
Create a MySQL repository database
Create an Azure SQL Database repository database
Uninstall DPA
Upgrade DPA
Upgrade DPA on Windows
Upgrade DPA on Linux
Upgrade DPA on an Amazon Machine Image instance
Upgrade DPA on an Azure VM
Administer
Introduction
Introduction to DPA
DPA architecture
DPA licensing
DPA license types
DPA registration and licensing options for clustered environments
Requirements for monitoring a database instance running in a VM cluster
Purchase and view DPA licenses
Activate DPA licenses
Allocate or deallocate DPA licenses
Troubleshoot over-allocated DPA licenses
Deactivate your DPA licenses
Register a database instance for monitoring with DPA
Database instances DPA can monitor
Register multiple database instances
Register an Oracle database
Register a SQL Server database
Register a Sybase database
Register a DB2 database
Register a MySQL database
Register an Amazon RDS for Oracle database
Register an Amazon RDS for SQL Server database
Register an Amazon RDS for MySQL or Aurora database
Register an Azure SQL database
Unregister a monitored database instance
Database instance groups
About monitoring SQL Server Availability Groups with DPA
About monitoring Oracle multitenent databases (CDBs)
Manually group database instances
Monitor database instances with DPA
Update a monitored database instance
Stop monitoring a database instance for a period of time
DPA troubleshooting tips
Investigate performance issues with DPA
Access DPA query or table tuning advisors
Use DPA's query performance analysis to find the root cause of performance issues
Investigate inefficient queries running against a table
Identify blocking sessions and deadlocks with DPA
Find and investigate unusually long wait times (anomalies)
About anomaly detection in DPA
Add an annotation to document a change to the database
Manage SQL statement properties
Name SQL statements
Exclude SQL statements from DPA charts and analysis
Add excluded SQL statements back to DPA charts and analysis
Resource metrics in DPA
View resource metrics in DPA
About DPA resource metric baselines
View or change DPA resource metric thresholds
DPA user accounts
DPA roles and privileges
Create a DPA user account and assign privileges
DPA user authentication options
Configure DPA to use Active Directory or LDAP
DPA alerts
View the status of DPA alerts
Configure a DPA alert
Send SNMP traps from DPA alerts
Stop DPA alerts for a period of time
Use DPA to alert on increases in SQL wait times
Create a custom DPA alert to display the name of the active node in a SQL Server cluster
Create a DPA alert group
Create and manage DPA contacts and contact groups
Notification policy for DPA alerts
DPA reports
About DPA reports
Access and run DPA reports
Create a DPA report
Search for a SQL statement to report on
Schedule a DPA report for email delivery
Create a DPA report group
Link together separate DPA servers
Set up a Central Server and add remote DPA servers
Configure authentication for the DPA Central Server
View information from remote servers on the DPA Central Server
Advanced configuration for the DPA Central Server
Automate tasks with the DPA REST API
Manage the tokens used for authentication to the DPA API
Learn about and experiment with the DPA API
Examples of using Python scripts to make DPA API calls
Examples of using PowerShell scripts to make DPA API calls
DPA administrative tasks
Stop and start DPA
Set advanced DPA configuration options
Enable SNMP Monitoring in SCOM
All Files
Administer
DPA Introduction
Introduction
Introduction to DPA
DPA architecture
DPA licensing
DPA user accounts
DPA alerts
DPA reports
DPA Introduction
See the following topics to get an overview of DPA features and learn about DPA architecture:
Introduction to DPA
DPA architecture
