About monitoring SQL Server Availability Groups with DPA
DPA provides status information, annotations, and alerts for your SQL Server Availability Groups (AGs).
- For information about options for registering SQL Server AGs, see Registration and licensing options for clustered environments.
- DPA does not support monitoring distributed AGs. DPA can monitor the SQL Server instances that participate in a distributed AG, but the AG monitoring features are not enabled for distributed AGs.
Automatic naming
When you register an AG listener, DPA automatically names the instance using the following format:
<PrimaryReplicaName> via <ListenerName>
When a failover occurs, the name is automatically updated to reflect the new primary replica.
If you manually change the display name of an AG that is registered via the listener, by default DPA overwrites the name each time the monitor starts. To change the default behavior and manually specify the name, change the advanced option AG_INSTANCE_NAME_UPDATE_ENABLED.
AG information in DPA
On the DPA homepage, the AG Status Summary box in the Status Summary area shows the number of database instances with partially healthy or not healthy AGs. As with other status boxes, click the filter next to a status to display only instances associated with the selected status.
The AG status icon
identifies database instances that include AGs. The color of the dot provides status information (described in the following section). Possible statuses are:
- Green for healthy
- Yellow for partially healthy
- Red for not healthy
- Gray for unknown
To view detailed information:
From the DPA homepage, click an AG status icon to open the Availability Group Summary view.
This view shows information about each AG in the database instance. DPA shows status information for primary replicas in the instance. For secondary replicas, the status of the primary replica is displayed if DPA is also monitoring the primary replica.
- Click any link to view detailed information about the databases and replicas in the AG.
How DPA determines the AG status
If the instance is monitored directly and acting as a primary replica
If you are monitoring the instance directly (not through a listener), DPA looks at the status of all AGs that the instance acts as the primary replica for, and displays the worst status.
Example: An instance is acting as the primary replica for four availability groups. Their statuses are:
- AG1: Healthy
- AG2: Healthy
- AG3: Partially Healthy
- AG4: Not Healthy
DPA shows the status as Not Healthy.
| AG1 (primary replica) |
AG2 (primary replica) |
AG3 (primary replica) |
AG4 (primary replica) |
DPA status |
| Healthy | Healthy | Partially Healthy | Not Healthy | Not Healthy |
If the instance is monitored directly and acting as a secondary replica
If an instance is acting as a secondary replica for any AGs, that AG's status is Unknown. If the instance also acts as a primary replica for one or more AGs, the Unknown status is ignored.
Example: An instance acts as the primary replica for three availability groups. Their statuses are:
- AG1: Healthy
- AG2: Healthy
The instance also acts as a secondary replica for one AG. Its status is Unknown.
DPA ignores the Unknown status, and shows the status as Partially Healthy.
AG4 (secondary replica) |
DPA status |
| Healthy | Healthy | Partially Healthy | Unknown | Partially Healthy |
If DPA shows the AG status as Unknown, that typically indicates that the instance is acting as a secondary replica for all AGs.
If the instance is monitored via the listener
If you are monitoring the instance via the listener, by default DPA displays the aggregate status as described above. However, you can change the advanced option AG_STATUS_ROLLUP_USE_PRIMARY to determine the status using only the AG associated with the listener.
AG alerts
DPA provides the following AG alerts: SQL Server Availability Group Failover and SQL Server Availability Group Status Change.
This alert is triggered when an AG failover occurs. DPA sends alerts based on how you registered instances:
- If you registered database instances directly (not through a listener), when a failover occurs DPA sends an alert for each instance involved in the failover that it is monitoring. For example, if an AG fails over from Instance1 to Instance2 and DPA is monitoring both instances, you receive two alerts. If DPA is monitoring only one of the instances, you receive only one alert.
- If you registered the AG through a listener and the AG associated with the listener fails over, DPA sends one alert, because the listener moves with the AG from Instance1 to Instance2.
If multiple AG failovers occur in a short period of time, DPA aggregates them into one alert per instance.
This alert is triggered when an AG status changes to Partially Healthy or Not Healthy. DPA evaluates AG statuses every 10 minutes by default. You are alerted if the status changes from Healthy to Partially Healthy or Not Healthy between the evaluations. If the status changes from Healthy to another status and then back to Healthy during the same evaluation period, you are not alerted.
Example: In this example, DPA is monitoring an instance that acts as a primary replica for three AGs. The following table shows how the alerts would behave for each of DPA's alert policies. The intervals are arranged from most noisy to least noisy.
| Interval | AG status (change in red) | Policy: Notify when level not visited since normal | Policy: Notify when level changes and is not normal | Policy: Notify when level is not normal |
| 1 | AG1 Healthy
AG2 Healthy AG3 Healthy |
No alert | No alert | No alert |
| 8 | AG1 Healthy
| 4 | AG1 Healthy
AG2 Not Healthy AG3 Not Healthy |
AG2 Not Healthy
AG3 Not Healthy |
AG2 Not Healthy
AG3 Not Healthy |
AG2 Not Healthy
AG3 Not Healthy |
| 6 | AG1 Healthy
AG2 Partially Healthy AG3 Partially Healthy |
No alert | AG2 Partially Healthy
| 2 | AG1 Healthy
AG2 Partially Healthy AG3 Healthy |
AG2 Partially Healthy | AG2 Partially Healthy | AG2 Partially Healthy |
| 3 | AG1 Healthy
AG3 Partially Healthy | AG3 Partially Healthy | AG2 Partially Healthy
AG3 Partially Not Healthy |
| 7 | AG1 Partially Healthy
AG1 Partially Healthy | AG1 Partially Healthy | AG1 Partially Healthy |
| 5 | AG1 Partially Healthy | AG1 Partially Healthy | AG1 Partially Healthy | AG1 Partially Healthy
Automatic annotations when AG failovers occur
Annotations are automatically added to wait time charts when an AG failover occurs. The annotations allow you to compare changes in performance before and after a failover.
The number of annotations depends on how you registered instances:
- If you registered database instances directly (not through a listener), when a failover occurs DPA adds an annotation for each instance involved in the failover that it is monitoring. For example, if an AG fails over from Instance1 to Instance2 and DPA is monitoring both instances, DPA adds two annotations. If DPA is monitoring only one of the instances, DPA adds only one annotation.
- If you registered the AG through a listener and the AG associated with the listener fails over, DPA adds one annotation.
If you do not want to add an annotation when an AG failover occurs, change the value of the advanced system option AG_EVENT_ANNOTATIONS_ENABLED.
