Examples of using PowerShell scripts to make DPA API calls
The following examples show PowerShell scripts that call the DPA API to retrieve information and perform DPA management functions. The first examples are snippets that demonstrate each API call individually. The last example is a full script that shows how to put the snippets together into a working script.
You can call the DPA API with any programming language that can send HTTP requests. See this topic for Python script examples.
Prerequisite
Before you can use scripts to make API calls, you must create a refresh token.
If your DPA server does not use HTTPS or your certificates are self-signed
The examples all use HTTPS, which can cause problems if your DPA server is not configured to use HTTPS or if your certificates are self signed. If this is the case, you can do either of the following:
- Run the examples using HTTP.
- Add the following code below the configuration section.
# Adding certificate exception to prevent API errors
add-type @"
using System.Net;
using System.Security.Cryptography.X509Certificates;
public class TrustAllCertsPolicy : ICertificatePolicy {
public bool CheckValidationResult(
ServicePoint srvPoint, X509Certificate certificate,
WebRequest request, int certificateProblem) {
return true;
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
Get an access token
The first step in using the API is to get an access token. An access token is required to make any API calls. This call POSTs the refresh token to DPA, which returns an access token to be used by all other API calls.
- If the call is successful, it prints out the data that was returned from DPA, including the
access_token, and then goes on to create HTTP Headers that will contain the access token and other information to be used on subsequent calls. - If the call is not successful it prints out the error message.
You must set the $baseURL and the $refreshToken variables to match your environment.
# Configure the variables below for the DPA Host
$baseURL = "https://localhost:8124/iwc/api/"
$refreshToken = "eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJNeVRva2VuIiwiaXN..."
# Get an access token
$authTokenURL = $baseURL + "security/oauth/token"
$body = @{"grant_type" = "refresh_token"
"refresh_token" = "$refreshToken"}
Try {
Write-Host "Getting Access Token..."
$dpaAuthResponse = Invoke-RestMethod -Uri $authTokenURL -Method POST -Body $body
$dpaAuthResponse | Format-List
Catch {
$_.Exception.ToString()
return
# If successful we will create our headers to be used for all API calls
$tokenType = $DpaAuthResponse.token_type
$accessToken = $DpaAuthResponse.access_token
$dpaHeader = @{}
$dpaHeader.Add("Accept", "application/json")
$dpaHeader.Add("Content-Type", "application/json;charset=UTF-8")
$dpaHeader.Add("Authorization", "$tokenType $accessToken")
# This will print out data like this:
access_token : eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1c2VyX25hbWUiOiJpZ25pdGUiLCJzY29wZSI6W10sImlkIjotMSwidXNlcl...
token_type : bearer
expires_in : 365
userType : repo
jti : e0d51295-2010-4ed4-b5ea-982a4e6ae1c5
Database Monitor examples
The following examples show how to use all Database Monitor calls.
Get information about one monitored database instance
# Get Monitor Information for a single database
$databaseId = 1
$monitorURL = $baseURL + "databases/$databaseId/monitor-information"
Try {
Write-Host "Get Monitor Information for database with id of $databaseId..."
$monitorJSON = Invoke-RestMethod -Method Get -Uri $monitorURL -Headers $dpaHeader -TimeoutSec 60
$monitor = $monitorJSON.data
$monitor | Format-List
Catch {
Get Monitor Information for database with id of 1...
dbId : 1
ip : 127.0.0.1
port : 1433
jdbcUrlProperties : applicationIntent=readOnly
connectionProperties :
databaseType : SQL Server
databaseVersion : 12.0.6205.1
databaseEdition : Enterprise Edition: Core-based Licensing (64-bit)
monitoringUser : ignite_next
defaultDbLicenseCategory : DPACAT2
assignedDbLicenseCategory : DPACAT2
assignedVmLicenseCategory :
monitorState : Monitor Running
oldestMonitoringDate : 2018-12-04T00:00:00.000-07:00
latestMonitoringDate : 2019-01-02T00:00:00.000-07:00
agListenerName :
agClusterName :
agName :
racInfo :
rac : False
linkedToVirtualMachine : False
rds : False
pdb : False
ebusiness : False
Start and stop monitoring a database instance given its database ID
$databaseId = 1
$monitorURL = $baseURL + "databases/$databaseId/monitor-status"
# Start monitoring a database instance given its database ID.
Try {
Write-Host "Start Monitor for database $databaseId..."
$command = @{"command" = "START"} | ConvertTo-Json
$monitorJSON = Invoke-RestMethod -Method Put -Uri $monitorURL -Body $command -Headers $dpaHeader -TimeoutSec 60
$result = $monitorJSON.data
Write-Host "Result: $result"
Write-Host "Waiting 15 seconds...`r`n"
Start-Sleep -s 15
Catch {
# Stop monitoring a database instance given its database ID.
Try {
Write-Host "Stop Monitor for database $databaseId..."
$command = @{"command" = "STOP"} | ConvertTo-Json
Start-Sleep -s 15
Catch {
Start Monitor for database 1...
Result: SUCCESS
Stop Monitor for database 1...
Result: SUCCESS
Get information about all monitored database instances
# Get Monitor Information for all databases
$monitorURL = $baseURL + "databases/monitor-information"
Try {
Write-Host "Get Monitor Information for all databases..."
$monitorListJSON = Invoke-RestMethod -Method Get -Uri $monitorURL -Headers $dpaHeader -TimeoutSec 60
$monitorList = $monitorListJSON.data
$monitorList | Format-Table -AutoSize
Catch {
dbId name ip port jdbcUrlProperties connectionProperties databaseType databaseVersion ...
1 DEV-DPA\SQLEXPRESS 10.10.10.1 1433 applicationIntent=readOnly SQL Server 12.0.6205.1 ...
3 DEVORA11_DEVORA11 10.10.10.2 1521 Oracle 11.2.0.1.0 ...
10 DEV-MYSQL:3306 10.10.10.3 3306 dumpQueriesOnException=true MySQL 5.7.19 ...
etc.
Stop and start monitoring for all database instances
$monitorURL = $baseURL + "databases/monitor-status"
# Start monitoring all database instances.
Try {
Write-Host "Starting all Monitors..."
Write-Host "Waiting 30 seconds...`r`n"
Start-Sleep -s 30
Catch {
# Stop monitoring all database instances.
Try {
Write-Host "Stopping all Monitors..."
Start-Sleep -s 30
Catch {
Result: SUCCESS
Result: SUCCESS
Update the user password for a monitored database instance
$databaseId = 1
$monitorURL = $baseURL + "databases/$databaseId/update-password"
Try {
Write-Host "Update the Monitor password for database $databaseId..."
$command = @{"password" = "NewPassword!"} | ConvertTo-Json
Write-Host "Result: $result`r`n"
Catch {
Update the Monitor password for database 1...
Result: SUCCESS
License Allocation examples
The examples below show how to use all License Allocation calls.
Get information about currently installed licenses
$licenseURL = $baseURL + "databases/licenses/installed"
Try {
Write-Host "Getting Installed license information with total amounts available for use and total amounts used..."
$licenseListJSON = Invoke-RestMethod -Method Get -Uri $licenseURL -Headers $dpaHeader -TimeoutSec 60
$licenseList = $licenseListJSON.data
$licenseList | Format-Table -AutoSize
Catch {
licenseProduct licenseCategory licensesAvailable licensesConsumed
DPACAT1 DPA_DB 100 22
DPACAT2 DPA_DB 100 16
DPAAzureSQL DPA_DB 0 0
DPAVM DPA_VM 100 12
Get license information for a single database instance
$databaseId = 1
$licenseURL = $baseURL + "databases/$databaseId/licenses"
Try {
Write-Host "Getting current license information for the database instance with database ID of $databaseId."
$licenseInfo = $licenseListJSON.data
$licenseInfo | Format-Table -AutoSize
Catch {
Getting current license information for the database instance with database ID of 1.
serverName overLicensed vmLicenseProduct performanceLicenseProduct
DEV-DPA False DPAVM DPACAT2
Update license information for a database instance
$databaseId = 1
# Add a DPACAT2 and a DPAVM license
$licenseAllocation = @{"performanceLicenseProduct" = "DPACAT2";
"vmLicenseProduct" = "DPAVM"} | ConvertTo-Json
Try {
Write-Host "Updating license for database id $databaseId..."
$licenseResultJSON = Invoke-RestMethod -Method Put -Uri $licenseURL -Body $licenseAllocation -Headers $dpaHeader -TimeoutSec 60
$licenseResult = $licenseResultJSON.data
Write-Host "New License Allocation result for the database instance with database ID of $databaseId."
$licenseResult | Format-Table -AutoSize
Catch {
# Remove the DPAVM license
"vmLicenseProduct" = "REMOVE"} | ConvertTo-Json
Try {
Catch {
Updating license for database id 1...
New License Allocation result for the database instance with database ID of 1.
DEV-DPA False DPACAT2
Annotation examples
The examples below show how to use all Annotation calls.
Get a list of annotations for the last 30 days
$databaseId = 1
$annotationURL = $baseURL + "databases/$databaseId/annotations"
# Dates are in ISO 8601 format ( 2018-12-31T12:00:00.000-07:00 )
$endTime = Get-Date
$startTime = $endTime.AddDays(-30)
$startTime = [System.Web.HttpUtility]::UrlEncode($startTime.ToString("yyyy-MM-ddTHH\:mm\:ss.fffzzz"))
$endTime = [System.Web.HttpUtility]::UrlEncode($endTime.ToString("yyyy-MM-ddTHH\:mm\:ss.fffzzz"))
$request = [System.UriBuilder]$annotationURL
$request.Query = "startTime=$startTime&endTime=$endTime"
$annotationURL = $request.Uri
Try {
Write-Host "Getting Annotations for the last 30 days..."
$annotationListJSON = Invoke-RestMethod -Method Get -Uri $annotationURL -Headers $dpaHeader -TimeoutSec 60
$annotationList = $annotationListJSON.data
$annotationList | Format-Table -AutoSize
Catch {
handleError $Error[0]
id title description createdBy time type
98 Test Title API Test Event created by DPA API DPA API 2018-12-04T18:13:04-07:00 Custom
99 Test Title API Test Event created by DPA API DPA API 2018-12-04T18:14:27-07:00 Custom
100 Test Title API Test Event created by DPA API DPA API 2018-12-04T18:16:46-07:00 Custom
etc.
Create a new annotation
$databaseId = 1
$createTime = Get-Date
# Dates are in ISO 8601 format, no millis ( 2018-12-31T12:00:00-07:00 )
$createTime = $createTime.ToString("yyyy-MM-ddTHH\:mm\:sszzz")
$body = @{"title" = "API Test Title";
"description" = "API Test Description";
"createdBy" = "Test API User";
"time" = "$createTime"} | ConvertTo-Json
Try {
Write-Host "Creating Annotation..."
$dpaResponseJSON = Invoke-RestMethod -Uri $annotationURL -Body $body -Method POST -Headers $dpaHeader -TimeoutSec 60
$dpaResponse = $dpaResponseJSON.data
$dpaResponse | Format-Table -AutoSize
$annotationId = $dpaResponse.id
Catch {
148 API Test Title API Test Description Test API User 2019-01-03T15:20:36-07:00 API
Delete an annotation
$databaseId = 1
$annotationId = 148
$annotationURL = $baseURL + "databases/$databaseId/annotations/$annotationId"
Try {
Write-Host "Deleting Annotation with id of $annotationID..."
$dpaResponseJSON = Invoke-RestMethod -Uri $annotationURL -Method DELETE -Headers $dpaHeader -TimeoutSec 60
Write-Host "Annotation with id of $annotationID deleted`r`n"
Catch {
Deleting Annotation with id of 148...
Annotation with id of 148 deleted
Database Registration examples
The examples below show how to use all Database Registration calls.
Register and unregister a SQL Server database instance for monitoring
This example registers a new SQL Server database instance, waits 60 seconds, and then unregisters the database instance.
# Register a SQL Server database instance for monitoring.
$registrationURL = $baseURL + "databases/register-monitor"
$body = @{"databaseType" = "SQLSERVER";
"serverName" = "127.0.0.1";
"port" = "1433";
"sysAdminUser" = "sa";
"sysAdminPassword" = "Password";
"monitoringUser" = "dpa_test_m";
"monitoringUserPassword" = "Password";
"monitoringUserIsNew" = $true;
"displayName" = "DPA_SQL2K12"} | ConvertTo-Json
Try {
Write-Host "Registering Database..."
$dpaResponseJSON = Invoke-RestMethod -Uri $registrationURL -Body $body -Method POST -Headers $dpaHeader -TimeoutSec 60
$newDbId = $dpaResponse.databaseId
Catch {
Write-Host "Waiting 60 seconds...`r`n"
Start-Sleep -s 60
# Un-register the SQL Server database instance.
if ($newDbId) {
$registrationURL = $baseURL + "databases/unregister-monitor"
$body = @{"databaseId" = $newDbId;
"removeMonitoringUser" = $true;
"removeDatabaseObjects" = $true;
"sysAdminPassword" = "Password"} | ConvertTo-Json
Try {
Catch {
databaseId result
70 SUCCESS
Unregistering Database...
databaseId result
70 SUCCESS
Register and unregister an Oracle database instance for monitoring
This example registers a new Oracle database instance, waits 60 seconds, and then unregisters the database instance.
# Register an Oracle database instance for monitoring.
$body = @{"databaseType" = "ORACLE";
"serviceNameOrSID" = "DPA_ORA11R1";
"port" = "1521";
"sysAdminUser" = "system";
"sysPassword" = "Password";
"monitoringUserTableSpace" = "USERS";
"monitoringUserTempTableSpace" = "TEMP";
"oracleEBusinessEnabled" = $false;
"displayName" = "DPA_ORA11R1"} | ConvertTo-Json
Try {
Catch {
Start-Sleep -s 60
# Un-register the Oracle database instance.
if ($newDbId) {
Try {
Write-Host "Unregistering Database..."
Catch {
databaseId result
71 SUCCESS
databaseId result
71 SUCCESS
Register and unregister a MySQL database instance for monitoring
This example registers a new MySQL database instance, waits 60 seconds, and then unregisters the database instance.
# Register a MySQL database instance for monitoring.
$body = @{"databaseType" = "MYSQL";
"port" = "3306";
"sysAdminUser" = "root";
"displayName" = "DPA_MYSQL56"} | ConvertTo-Json
Try {
Catch {
Start-Sleep -s 60
# Un-register the MySQL database instance.
if ($newDbId) {
Try {
Catch {
databaseId result
72 SUCCESS
databaseId result
72 SUCCESS
Full working script
The following script combines all of the examples shown above into a script that can be run.
# Examples:
# - Get an access token
# - Database Monitor Examples
# - Get Monitor Information for a single database
# - Start or Stop monitoring a database instance given its database ID
# - Get Monitor Information for all databases
# - Start monitoring for all database instances
# - Stop monitoring for all database instances
# - ERROR: Get Monitor Information for a database that doesn't exist
# - ERROR: Start a database that doesn't exist
# - Licensing Examples
# - Get the currently installed license information
# - Get License Information for a single database
# - Update License Information for a single database
# - Annotation Examples
# - Gets a List of annotations for the last 30 days
# - Create a new annotation
# - Delete an annotation
# - Registration Examples
# - Register a MySQL database instance for monitoring
# - Un-register the MySQL database instance
$databaseId = 1
# Nothing to configure below this line
# Function to parse the Response Data from DPA and print
# out the error information
Function handleError ($thisError) {
Write-Host "--------------------------------------------------------------------" -ForegroundColor Red
Write-Host "Caught Exception at line:" $_.InvocationInfo.ScriptLineNumber -ForegroundColor Red
if ($_.Exception.Response) {
$streamReader = [System.IO.StreamReader]::new($_.Exception.Response.GetResponseStream())
$errResp = $streamReader.ReadToEnd()
$streamReader.Close()
if ($errResp) {
# This will format the JSON
$errResp = $errResp | ConvertFrom-Json | ConvertTo-Json -Depth 100
Write-Host $thisError.Exception.Message -ForegroundColor Red
Write-Host "Response:`r`n$errResp" -ForegroundColor Red
else {
Write-Host $_.Exception.ToString() -ForegroundColor Red
# Uncomment this if you are getting trust errors and would
# like to run with self-signed certificates.
# add-type @"
# using System.Net;
# using System.Security.Cryptography.X509Certificates;
# public class TrustAllCertsPolicy : ICertificatePolicy {
# public bool CheckValidationResult(
# ServicePoint srvPoint, X509Certificate certificate,
# WebRequest request, int certificateProblem) {
# return true;
# [System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
Try {
Catch {
Write-Host 'Error getting authentication token, cannot continue' -ForegroundColor Red
return
$tokenType = $dpaAuthResponse.token_type
$accessToken = $dpaAuthResponse.access_token
$dpaHeader = @{}
# Database Monitor Examples
Try {
$monitor | Format-Table -AutoSize
Catch {
# Start or Stop monitoring a database instance given its database ID.
# If it is already running stop it and then restart it
# If it is not running start it and then stop it
if ($monitor.monitorState -eq "Monitor Running") {
$changeCommand = "STOP"
$revertCommand = "START"
elseif ($monitor.monitorState -eq "Monitor Stopped") {
$changeCommand = "START"
$revertCommand = "STOP"
Try {
Write-Host "$changeCommand Monitor for database $databaseId..."
$command = @{"command" = $changeCommand} | ConvertTo-Json
Start-Sleep -s 15
Write-Host "$revertCommand Monitor for database $databaseId..."
$command = @{"command" = $revertCommand} | ConvertTo-Json
Start-Sleep -s 15
Catch {
Try {
# Keep a list of running or started monitors to be used later
$runningIds = @()
foreach ($monitor in $monitorList) {
if ($monitor.monitorState -eq "Monitor Running" -or
$monitor.monitorState -eq "Monitor Start No License" -or
$monitor.monitorState -like '*Start*')
$runningIds += $monitor.dbId
Write-Host "Running Monitors: $runningIds`r`n"
Catch {
Try {
Start-Sleep -s 30
Catch {
Try {
Start-Sleep -s 30
Catch {
# Try to put it back the way we found it by restarting the ones that were running
foreach ($dbId in $runningIds) {
Try {
$monitorURL = $baseURL + "databases/$dbId/monitor-status"
Write-Host "Starting Monitor for database $dbId..."
Catch {
# Update the monitor database user password (Un-comment to use)
# $monitorURL = $baseURL + "databases/$databaseId/update-password"
# Try {
# Write-Host "Update the Monitor password for database $databaseId..."
# $command = @{"password" = "NewPassword!"} | ConvertTo-Json
# $monitorJSON = Invoke-RestMethod -Method Put -Uri $monitorURL -Body $command -Headers $dpaHeader -TimeoutSec 60
# $result = $monitorJSON.data
# Write-Host "Result: $result`r`n"
# Catch {
# handleError $Error[0]
# Try to cause some errors...
# Get Monitor Information for a database that doesn't exist
$monitorURL = $baseURL + "databases/-1/monitor-information"
Try {
Write-Host "Get Monitor Information for invalid database..."
Catch {
# Start a database that doesn't exist
$monitorURL = $baseURL + "databases/-1/monitor-status"
Try {
Write-Host "START Monitor for invalid database..."
Catch {
# Licensing Examples
# Get the currently installed license information
Try {
Catch {
# Get License Information for a single database
Try {
Catch {
# This will Update License Information for a single database setting the
# Performance License and the VM License to what it currently is.
# It should succeed but it should make no changes.
$dbProduct = $licenseInfo.performanceLicenseProduct
$vmProduct = $licenseInfo.vmLicenseProduct
$licenseAllocation = @{"performanceLicenseProduct" = $dbProduct;
"vmLicenseProduct" = $vmProduct} | ConvertTo-Json
Try {
Catch {
# Annotation Examples
# Gets a List of annotations for the last 30 days
# Dates are in ISO 8601 format ( 2018-12-31T12:00:00-07:00 )
$endTime = Get-Date
Try {
Catch {
# Create a new annotation
Try {
Catch {
# Delete an annotation
if ($annotationId) {
Try {
Catch {
# Registration Examples
"port" = "1433";
Try {
Catch {
Start-Sleep -s 60
if ($newDbId) {
Try {
Catch {
"port" = "1521";
Try {
Catch {
Start-Sleep -s 60
if ($newDbId) {
Try {
Catch {
"port" = "3306";
Try {
Catch {
Start-Sleep -s 60
if ($newDbId) {
Try {
Catch {
# End of script
