Administer > DPA administrative tasks > Set advanced DPA configuration options
You can use advanced options to change DPA's default behavior. For example, you can change how long DPA stores data about a database instance, or prevent DPA from annotating wait time charts when a PDB is moved.
  1. In the DPA menu bar, click Options.
  2. Under Administration > Configuration, click Advanced Options.
    The System Options tab lists options that apply to all database instances.
  3. If you are setting an option that applies to a single database instance, click DB Instance Options and select the database instance.
  4. Click the name of an option to open the Edit Option dialog.
  5. To change an option value, enter the New Value and click Update.
