Administer > Monitor database instances with DPA
The DPA homepage displays a list of the monitored database instances with status and wait time information. Click Action to start or stop monitoring.
Monitoring is always active after it is started. It is not necessary to restart the DPA monitor if the repository instance or the monitored database instance was unavailable for a period of time. Monitoring resumes when both are available again.
If there is a period of time when monitoring should not occur, you can stop monitoring a database instance.
If you are having problems connecting to or monitoring a database instance, see Troubleshooting tips.
