Register an Oracle database
If you are monitoring an Oracle Real Application Cluster (RAC), see Registration and licensing options for clustered environments.
To register an Oracle database for DPA to monitor:
- On the DPA homepage, click Register DB Instance for Monitoring.
- Under Self-Managed, click Oracle.
- Click Next.
- Complete the wizard panels as described in the following table.
| Panel | Instructions |
| Enter Monitored Database Instance Connection Information |
DPA monitors all databases within the instance. If more than one instance exists on the server, you must register each instance separately in DPA. Oracle database instances have three connection options:
Direct ConnectEnter the Service Name or System Identifier (SID), host name or IP address, and port. The default port is 1521. TNS Connect DescriptorThe Connect Descriptor value contains everything after
LDAP or TNS NameTo use this option, Oracle Name Resolution must be configured. For instructions, see Connect to Oracle using name resolution. After you configure Oracle Name Resolution, you can use the LDAP/TNS Name when registering additional monitored database instances. DPA uses the Oracle network configuration If connection information other than the name has changed, update the If the name has changed, update the |
RAC instancesIf this is an Oracle Real Application Clusters (RAC) instance, there may be listener configuration changes needed if you are not listening on the physical IP address. SolarWinds recommends:
DBA userEnter DBA credentials for DPA to register the database instance. |
| Enter the Monitoring User |
Create or specify the account that DPA will use to gather information. To ensure that the account has the required permissions, SolarWinds recommends creating a new account. To create a new account:
To specify an existing account:
If you create the user manually, DPA uses the default Tablespaces for that user. If you are registering multiple Oracle Real Application Clusters (RAC) nodes, you may receive an error that the user already exists. You can create a different monitoring user or clear the Create a New Monitoring User check box and continue. |
| Oracle Monitoring Information |
If the monitored instance contains the Oracle E-Business Suite, DPA can collect additional information about the suite. DPA can capture Oracle E-Business data to identify the screens, modules, and users generating the database requests. This gives you increased visibility into the causes of performance problems in the Oracle E-Business Suite, Oracle Enterprise Resource Planning (ERP), and Oracle Applications environments. The SYS password is requested only if remote login as SYS is enabled on the monitored Oracle instance. This option is not available for Amazon RDS instances. If you do not have remote SYS access to the computer, click the link to open the Manual Steps for Monitored Database Instance Registration. You can run a script to run on the monitored instance to install a utility package for DPA that grants Execute permissions for that package to the monitoring user. To register the monitored database instance manually:
| Oracle Repository Tablespace |
If your repository database is not Oracle, the wizard skips this step. Choose the tablespace in the repository database to store DPA performance data for this monitored instance. By default, the performance data is stored in the default tablespace of the repository user. However, data for monitored instances can be stored in separate tablespaces. |
| Select the Alert Groups |
If you have no Alert Groups set up, or if this new database instance does not match the database type of the Alert Group, the wizard skips this step. Alert Groups simplify alert configuration and help make alerting more consistent across the monitored database instances. Select the Alert Groups you want the new database instance to join. |
| Summary | Review the information and click Register Database Instance. |
| Database Instance Registration Complete | Click Finish to return to the DPA homepage. |
If you register a database instance within the 14-day trial period, DPA begins monitoring the instance immediately. After the trial period, you must activate a license to monitor the database instance.
