Documentation forNetFlow Traffic Analyzer
Top XX Receivers (Classic Chart)
This widget provides a list of the XX receivers consuming the bandwidth over your monitored network. Receivers are listed with the amount of data transferred, in both bytes and packets.
When placed on the Node Details or Interface Details view, this widget provides a view of the receivers responsible for the most traffic passing through the viewed node or interface over the selected period of time.
View more details about listed receivers
Click a receiver endpoint to open the NetFlow Receivers Summary View.
Click + to expand a listed endpoint and display a list of the nodes and their respective interfaces over which data are currently being received by the endpoint.
Click a node or an interface to display the appropriate receiver traffic related to the selected node or interface. For more information, see NetFlow Endpoint View.
Top XX Receivers (Endpoint Centric)
You can customize an endpoint-centric version of this widget and place it on the NetFlow Node Details or Interface Details view.
The endpoint-centric Top XX Receivers widget provides a ranked list of receivers to which the selected node or interface initiated traffic.
For more information about adding endpoint-centric widgets, see Add endpoint-centric widgets to NTA views.
The table below the chart provides the following information:
Column Title Contents
Hostname Displays the name or IP address of the receiving endpoint.
Ingress Bytes, Egress Bytes
Ingress Packets, Egress Packets
Displays the amount of data, in both bytes and packets, routed through the viewed object received by the listed endpoint over the specified period of time.
The columns displayed depend on the flow direction set in the top left corner of the view (either only Ingress Bytes, or only Egress Bytes, or both columns).
Percent (Utilization) Displays the percentage of all traffic routed through the viewed node or interface that is received by the listed endpoint over the specified period of time.
The first value describes the percentage of the appropriate item based on items shown by the chart. Individual items in the legend add up 100%. This percentage can be absolute or relative. For more information, see Set the Percentage type for Top XX lists.
A value in parentheses is available only for interfaces. It describes how the appropriate item utilizes the interface bandwidth in percentage.
If the utilization is approximately twice as high as it should be, for example 150% instead of 75%, it might be caused by flow duplication. For more information, see Resolve duplicate flows.
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
  1. Click Edit to go to the Edit widget page.
  2. Make the appropriate changes.
  1. Click Submit.
Edit the widget for the current session
You can change the contents and looks of the widget for the current session only. After you leave the view, your changes will be lost and default settings applied.
Chart Style and Data Units
  1. In the Data drop-down, select the appropriate chart style (Area Chart or Pie Chart).
  2. If you have selected the Area Chart type, you can further select what data you want to display by the widget.
    1. In the Data Units drop-down, select the appropriate unit.
Time Period and Flows Direction
To change the time period and Flows direction shown by all widgets in the view, click next to the appropriate setting below the view name and define the settings.
For more information about time settings, see Edit time settings for NTA views.
For more information about Flow direction settings, seeEdit flow direction in NTA views.
