Top XX Autonomous Systems (Classic Chart)
This widget provides a list of the most bandwidth‑intensive autonomous systems. Autonomous systems are listed with the amount of data (kbps) transferred, in both bytes and packets, and the percentage of all traffic generated by the autonomous system over the specified time period.
When placed on the Node Details or Interface Details view, this widget provides a view of the autonomous systems responsible for the most traffic passing through the viewed node or interface over the selected period of time.
To find out more about autonomous systems monitored by NTA, see Managing Autonomous System Networks.
View more details about displayed autonomous systems
Click a listed autonomous system to open it in the NetFlow BGP Summary View.
Click + to expand a listed autonomous system and display a list of nodes and their respective interfaces relevant for the selected autonomous system.
Click a listed node or interface to display the relevant autonomous system traffic traversing through the selected node or interface in the NetFlow Autonomous Systems View.
Table legend
The table below the chart provides the following information:
Column Title | Contents |
Autonomous System | The autonomous system ID. |
Ingress Bytes, Egress Bytes Ingress Packets, Egress Packets |
Displays the amount of data (in bytes and packets) flowing to the selected autonomous system through the viewed node or interface. The columns displayed depend on the flow direction set in the top left corner of the view (either only Ingress Bytes, or only Egress Bytes, or both columns). |
Percent (Utilization) |
Displays the percentage of all traffic through the viewed object that can be attributed to listed autonomous systems. The first value describes the percentage of the appropriate item based on items shown by the chart. Individual items in the legend add up 100%. This percentage can be absolute or relative. For more information, see Set the Percentage type for Top XX lists. A value in parentheses is available only for interfaces. It describes how the appropriate item utilizes the interface bandwidth in percentage. If the utilization is approximately twice as high as it should be, for example 150% instead of 75%, it might be caused by flow duplication. For more information, see Resolve duplicate flows. |
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
- Click Edit to go to the Edit widget page.
- Make the appropriate changes.
- Click Submit.
Edit the widget for the current session
You can change the contents and looks of the widget for the current session only. After you leave the view, your changes will be lost and default settings applied.
Chart Style and Data Units
- In the Data drop-down, select the appropriate chart style (Area Chart or Pie Chart).
- If you have selected the Area Chart type, you can further select what data you want to display by the widget.
- In the Data Units drop-down, select the appropriate unit.
Time Period and Flows Direction
To change the time period and Flows direction shown by all widgets in the view, click next to the appropriate setting below the view name and define the settings.
For more information about time settings, see Edit time settings for NTA views.
For more information about Flow direction settings, seeEdit flow direction in NTA views.
