Documentation forNetFlow Traffic Analyzer
NetFlow BGP Summary view
This view summarizes traffic details for autonomous systems and autonomous system conversations in your network.
To display traffic details related to a specified autonomous system or autonomous systems conversation, see NetFlow Autonomous System View or Autonomous Systems Conversation View.
Access the BGP Summary View
  1. Click My Dashboards > NetFlow > BGP.
  2. This view displays all autonomous systems monitored by NTA.
  3. Click an autonomous system in the Top XX Autonomous Systems widget.
  4. This view displays only the selected autonomous system in the BGP summary view.
  5. Click an autonomous systems conversation in the Top XX Autonomous Systems Conversations widget.
  6. This view displays only the selected autonomous system conversation in the BGP summary view.
Default widgets
The following widgets are available on this view by default:
Customize views
You can add or remove widgets on your views, change the time period, and change the flow direction settings shown by widgets on the view:
  • Click Customize Page to add widgets not present in the default view. For more information, see Edit views.
  • Click the arrow under the view title designating the time period applied to all default view widgets to change the time period. For more details, see Edit time settings for NTA views.
  • If you are viewing endpoint data at the interface level, you also have the option to designate the direction of the selected endpoint traffic over the interface you are monitoring. For more information, see Edit flow direction in NTA views.
Widgets added to a custom view may not be subject to the time period and flow direction controls.
Further controls on the view
Export to PDF
Save the current view as a PDF file.
NetFlow Settings
Access settings relevant for collecting and displaying your Flow and CBQoS data.
Flow Navigator
For more details about searching for certain data or filtering the view, see Search and filter tools.
