Documentation forNetFlow Traffic Analyzer
NetFlow Countries Summary view
This view provides the insight into the traffic associated with countries.
To display traffic details related to a specified country, see NetFlow Country View.
Access the Countries Summary View
  1. Click My Dashboards > NetFlow > Countries.
  2. This view displays top conversations monitored by NTA in your network.
  3. Click a country in the Top XX Countries widget to filter the Countries Summary view by the selected country.
  4. This view displays the sum of traffic for all monitored endpoints belonging to the selected country.
Default widgets
The following widgets are available by default in the NetFlow Countries Summary view:
Customize views
You can add or remove widgets on your views, change the time period, and change the flow direction settings shown by widgets on the view:
  • Click Customize Page to add widgets not present in the default view. For more information, see Edit views.
  • Click the arrow under the view title designating the time period applied to all default view widgets to change the time period. For more details, see Edit time settings for NTA views.
  • If you are viewing endpoint data at the interface level, you also have the option to designate the direction of the selected endpoint traffic over the interface you are monitoring. For more information, see Edit flow direction in NTA views.
Widgets added to a custom view may not be subject to the time period and flow direction controls.
Further controls on the view
Export to PDF
Save the current view as a PDF file.
NetFlow Settings
Access settings relevant for collecting and displaying your Flow and CBQoS data.
Flow Navigator
For more details about searching for certain data or filtering the view, see Search and filter tools.
