Search and filter tools
NTA views are customizable and display a large amount of traffic data organized by different widgets. To quickly navigate the views, use the following tools:
- Flow Navigator allows you to define and apply a filter to data collected by NTA, so that the displayed page shows only the information you need. For more information, see Custom NetFlow views.
 - Search field in the top right corner of the view allows you to search for endpoints or applications and ports. For more information, see Search by application or Port or Search by endpoint.
You can use a filter to exclude applications that you do not want to see. For more information, see Application Filtered view.
