Top XX Countries
This widget provides a view of the countries hosting endpoints that transmit the most data through the viewed node or interface over the selected period of time.
When placed on the Node Details or Interface Details view, this widget provides a view of the countries responsible for the most traffic passing through the viewed node or interface over the selected period of time.
View more details about displayed countries
Click a country to open it in the NetFlow Countries Summary view filtered by the selected country. For more information, see NetFlow Countries Summary View.
Click + to expand a listed conversation and display the list of nodes and their respective interfaces through which the selected country is currently passing data.
Click a node or interface to display the NetFlow Country detail view showing statistics for the selected country traffic traversing through the appropriate node or interface. For more information, see NetFlow Country View.
Top XX Countries (Endpoint Centric)
You can customize an endpoint-centric version of this widget and place it on the NetFlow Node Details or Interface Details view.
The endpoint-centric Top XX Countries widget provides a ranked list of countries to and from which the selected node or interface initiated or terminated traffic.
For more information about adding endpoint-centric widgets, see Add endpoint-centric widgets to NTA views.
The table below the chart provides the following information:
| Column Title | Contents |
| Country | The name of the country and its flag, if available. |
Ingress Bytes, Egress Bytes Ingress Packets, Egress Packets |
Displays the amount of data (in bytes and packets) traceable to the listed country over the selected period of time. The columns displayed depend on the flow direction set in the top left corner of the view (either only Ingress Bytes, or only Egress Bytes, or both columns). |
| Percent (Utilization) |
Displays the percentage of all traffic over the viewed node or interface that is traceable to the listed country.
The first value describes the percentage of the appropriate item based on items shown by the chart. Individual items in the legend add up 100%. This percentage can be absolute or relative. For more information, see Set the Percentage type for Top XX lists. A value in parentheses is available only for interfaces. It describes how the appropriate item utilizes the interface bandwidth in percentage. If the utilization is approximately twice as high as it should be, for example 150% instead of 75%, it might be caused by flow duplication. For more information, see Resolve duplicate flows. |
Widgets in the SolarWinds Platform Web Console are edited on the Edit Resource page. The options available depend on individual widgets.
If you are logged in using a User ID with administrative privileges, you can change the way a widget is displayed for all users.
- Click Edit in the header of the widget.
- Customize the available options:
- Title.
- Subtitle.
- Maximum Number of Items to Display.
- Chart customization options. For more information, see Customize charts for all users in NTA.
- Click Submit.
