Top XX Autonomous Systems
When placed on the Node Details or Interface Details view, this widget provides a view of the autonomous systems responsible for the most traffic passing through the viewed node or interface over the selected period of time.
To find out more about autonomous systems monitored by NTA, see Managing Autonomous System Networks.
View more details about displayed autonomous systems
Click a listed autonomous system to open it in the NetFlow BGP Summary View.
Click + to expand a listed autonomous system and display a list of nodes and their respective interfaces relevant for the selected autonomous system.
Click a listed node or interface to display the relevant autonomous system traffic traversing through the selected node or interface in the NetFlow Autonomous Systems View.
The table below the chart provides the following information:
| Column Title | Contents |
| Autonomous System | The autonomous system ID. |
Ingress Bytes, Egress Bytes Ingress Packets, Egress Packets |
Displays the amount of data (in bytes and packets) flowing to the selected autonomous system through the viewed node or interface. The columns displayed depend on the flow direction set in the top left corner of the view (either only Ingress Bytes, or only Egress Bytes, or both columns). |
| Percent (Utilization) |
Displays the percentage of all traffic through the viewed object that can be attributed to listed autonomous systems. The first value describes the percentage of the appropriate item based on items shown by the chart. Individual items in the legend add up 100%. This percentage can be absolute or relative. For more information, see Set the Percentage type for Top XX lists. A value in parentheses is available only for interfaces. It describes how the appropriate item utilizes the interface bandwidth in percentage. If the utilization is approximately twice as high as it should be, for example 150% instead of 75%, it might be caused by flow duplication. For more information, see Resolve duplicate flows. |
Widgets in the SolarWinds Platform Web Console are edited on the Edit Resource page. The options available depend on individual widgets.
If you are logged in using a User ID with administrative privileges, you can change the way a widget is displayed for all users.
- Click Edit in the header of the widget.
- Customize the available options:
- Title.
- Subtitle.
- Maximum Number of Items to Display.
- Chart customization options. For more information, see Customize charts for all users in NTA.
- Click Submit.
