Documentation forServer & Application Monitor
Troubleshoot AppInsight for IIS in SAM
Use the following sections to resolve AppInsight for IIS issues related to configuration and performance counters:
In addition to the following troubleshooting tips, search the SolarWinds Success Center.
AppInsight for IIS widgets do not populate with data, or "No data is currently available" messages appears
Check the related application monitor, as well as the parent AppInsight for IIS template, to determine if any components were disabled.
InvokeMethod messages in logs
WinRM is the default transport method used to fetch data for WMI-based component monitors. If monitoring Windows Server 2008 nodes with AppInsight for IIS, the following message may appear in application logs:
{{ERROR SolarWinds.APM.Probes.Management.WinRmFeatureService - Windows version 6.1.7601 with SP 1 does not support InvokeMethod }}.
The default log location is C:\ProgramData\SolarWinds\Logs\APM\ApplicationLogs.
This message appears because the WinRM Invoke method is not supported by Windows Server 2008. Fallback should occur so polling continues for IIS servers.
Polling fails on Windows Server 2008 R2 SP1 nodes and applications switch to Unknown state
Windows Server .NET 4.8 agents expect a later version of PowerShell, so SolarWinds.APM.Probes.CustomWmiProbe- and Microsoft.Management.Infrastructure-related errors appear in logs. As a workaround, install PowerShell 3.0 or later on target servers. PowerShell 5.1 is recommended. Click here for details.
