Documentation forServer & Application Monitor
HPE StoreOnce System
This SAM application monitor template assesses the overall health and performance of HPE StoreOnce System for enterprise backup, recovery, and deduplication storage.
The application monitor template includes PowerShell-based component monitors built-in for monitoring components and metrics across system health, alerts, storage, services, throughput, cloud activity, and housekeeping operations.
Prerequisites
Before using the HPE StoreOnce template, the following must be available:
  • HPE StoreOnce REST API version 4.1.x or newer.
  • The HPE StoreOnce appliance must be reachable from the SolarWinds execution host.
  • The appliance must be added to SolarWinds Platform as an External Node.
  • HTTPS connectivity to the appliance.
  • PowerShell execution must be available on the SAM execution host. PowerShell 5.1 should be installed and configured on target servers. For details, see Use PowerShell in SAM.
Learn about templates created by members of the THWACK community for later versions.
Credentials
A valid HPE StoreOnce local account must be configured in SAM credentials with permission to access the required REST API endpoints.
Quick Configuration
  1. Add the HPE StoreOnce System appliance as an External Node in SolarWinds Platform.
  2. Configure the HPE StoreOnce local account in the SAM credential settings. The password is used by the monitor scripts only for API authentication.
  3. Assign the HPE StoreOnce System application template to the External Node.
Default Settings
The HPE StoreOnce System application monitor includes settings inherited from the template. Once assigned to a node, these can be overridden, see Assigned Application Monitor.
Application Monitor Name:
Custom Application Details View:
No, use Default Application Details View
Polling Frequency:
300 seconds
Polling Timeout:
300 seconds
Advanced Settings
Preferred Polling Method:
Agent
Debug logging:
Off
Number of log files to keep:
30. The number of most recent log files to be kept for this application when debug logging is on.
Platform to run polling job on:
x64
Custom Properties:
Available when the template itself is modified.
Component monitors
HPE StoreOnce System Health
Authenticates to the HPE StoreOnce REST API and checks the system operational mode.
HPE StoreOnce Active Alerts
Retrieves and returns the count of currently ACTIVE alerts grouped by severity.
HPE StoreOnce NAS Share Summary
Retrieves NAS shares status summary from the HPE StoreOnce appliance dashboard. Returns count of NAS shares by status: Ok, Warning, Critical, Unknown, and Total.
HPE StoreOnce Appliance Status
Retrieves the overall appliance status from the HPE StoreOnce dashboard API. Returns the status string and a numeric value (OK=0, Warning=1, Critical=2).
HPE StoreOnce Disk Utilization Statistics
Retrieves disk utilization statistics from the HPE StoreOnce hardware API over a configurable rolling window (default: 7 days).
Returns total disk count, failed/degraded/unhealthy counts, max disk temperature, max power-on hours, total reallocated sectors, and SSD/HDD inventory breakdown.
HPE StoreOnce CPU Utilization Statistics
Retrieves CPU utilization statistics from the HPE StoreOnce hardware API over a configurable rolling window (default: 7 days).
Returns average and peak CPU utilization, user/system/idle/iowait/irq breakdowns, and the number of 5-minute data points collected.
HPE StoreOnce Memory Utilization Statistics
Retrieves memory utilization statistics from the HPE StoreOnce hardware API over a configurable rolling window (default: 7 days).
Returns average and peak memory/swap usage, minimum available memory, sample count, and additional memory byte metrics such as physical memory, swap, dirty/writeback, active/inactive file, and slab memory.
HPE StoreOnce D2D Service Status
Retrieves D2D services status from the HPE StoreOnce API and returns overall health status plus selected service statuses as separate statistics.
HPE StoreOnce CAT Throughput
Retrieves CAT throughput parametrics from the HPE StoreOnce API and returns average and peak session counts, network throughput, and sample count.
HPE StoreOnce VTL Throughput
Retrieves VTL throughput parametrics from the HPE StoreOnce API and returns average read/write throughput, average and peak open cartridge counts, and sample count.
HPE StoreOnce NAS Throughput
Retrieves NAS throughput parametrics from the HPE StoreOnce API and returns average transmitted/received throughput, average and peak open file descriptors, average and peak dedupe sessions, and sample count.
HPE StoreOnce Catalyst Cloud Metric
Retrieves Catalyst Cloud parametrics from the HPE StoreOnce API and returns average read/write throughput, average and peak RTT, request counters, network limit utilization, and sample count.
HPE StoreOnce Housekeeping Metrics
Retrieves SMM housekeeping parametrics from the HPE StoreOnce API and returns processed bytes, processed bytes throughput, processed bytes per second, freed bytes, compacted bytes, dereferenced bytes, pending bytes, queue size, jobs processed, and jobs received.
