Monitor IP addresses and DHCP servers
SolarWinds Observability SaaS provides visibility into IP address usage and DHCP server health across your network. This feature helps you identify IP utilization trends, detect DHCP scope exhaustion risk, and troubleshoot address-related issues.
How IP address and DHCP monitoring works
SolarWinds Observability SaaS collects IP address and DHCP data through Network Collectors or Platform-connected SolarWinds Observability Self-Hosted deployments.
Data is collected using network discovery scans, DHCP server polling, and streamed IP management data. The collected data is displayed in IP Address Management views in SolarWinds Observability SaaS.
Requirements
To monitor IP addresses and DHCP servers, the following is required:
A Network Collector version 2025.1.1 or later - based on the devices and features to monitor in SolarWinds Observability SaaS.
Version Feature 2025.1.1 Monitor DHCP servers and IP addresses. You must add the entities directly in the Network Collector web console. See Add DHCP servers and subnets in a Network Collector web console. 2025.2.1+ Manage DHCP servers and IP addresses in SolarWinds Observability SaaS. 2026.2+ Add and monitor KEA DHCP servers. Earlier versions do not support the API that KEA onboarding requires. 2026.4+ Create or manage reservations on KEA servers. -
A Platform-connected SolarWinds Observability Self-Hosted with
A SolarWinds Observability Self-Hosted license that includes IP address management
IP Management enabled during Platform Connect configuration
KEA DHCP server requirements
To monitor KEA DHCP servers, ensure your environment meets the following requirements.
For detailed configuration instructions, see Requirements for monitoring Kea servers in IPAM documentation.
| Category | Requirement |
| Supported versions | KEA 3.0.0 (base LTS) through 3.1.3. |
| Control socket | Configure an HTTP or HTTPS control socket. HTTPS requires TLS. |
| Authentication | Basic authentication is required. |
| Hook libraries |
The following libraries must be loaded:
Add a DHCP server for monitoring
You can add a DHCP server for monitoring, or enable DHCP monitoring on an already monitored device. Use this workflow to add DHCP servers in SolarWinds Observability SaaS.
You can also add the devices on the Network Collector or in Platform-connectedSolarWinds Observability Self-Hosted and enable DHCP monitoring in the corresponding web console.
In SolarWinds Observability SaaS, Click Network > IP Address Management > DHCP Servers tab, and then click Add DHCP Server.
To open the wizard, you can also click Add Data > Network > DHCP Server Monitoring.
Choose whether to configure DHCP monitoring on an existing monitored device, or to add a new device for DHCP monitoring.
To enable DHCP monitoring on a monitored device, choose Select an existing monitored device, then select a network device or host that is not already designated as a DHCP server and click Next.
To add a new device for monitoring, select Add new device:
- Click Next.
- Choose whether to use an existing Network Collector or to deploy a new Network Collector and click Next. For help with Network Collectors, see Network Collector and Add DHCP servers and subnets in a Network Collector web console.
- Enter polling details and click Next.
The device will be added as either a network device or a host, depending on which polling method you select.
- The ICMP and SNMP polling methods add new devices as network devices.
- The WMI polling method adds new devices as hosts.
On Create Device Summary, review the summary, and then click Next.
On Credentials, select existing credentials or create a new set of credentials for DHCP monitoring. Available credential types may differ based on the devices you are adding.
Supported credentials include Windows, Cisco, ASA, ISC, Infoblox, or KEA credentials.
Review the settings.
Review the Create DHCP Server Summary, and then complete the wizard.
The DHCP server configuration is propagated to the Network Collector and the initial scan starts. DHCP scopes and subnets usually appear within 15-45 minutes.
Start an on-demand DHCP scan
To refresh DHCP data manually:
In SolarWinds Observability SaaS, click Network > IP Address Management.
Go to the DHCP servers tab.
Click the vertical ellipsis for the server and select Scan Now.
The DHCP server is updated automatically when the scan completes.
Configure DHCP server scanning
After a DHCP server is added, you can adjust scanning behavior and update the display name, VLAN IDs and locations, and DHCP monitoring credentials.
In SolarWinds Observability SaaS, click Network > IP Address Management > DHCP servers.
Click the vertical ellipsis for the server and select Edit.
Update the server display name if needed.
Under Settings, configure:
Scan frequency for scopes and leases
Automatic scope and subnet import
Subnet scanning frequency
VLAN ID and Location, if applicable
Under Credentials, update credentials for polling DHCP server data.
Click Save.
View data relevant for IP monitoring and DHCP servers
In SolarWinds Observability SaaS, click Network to display the Network > IP Management.
Review the IP address management overview:
To view subnets and DHCP scopes with highest percent utilization, review the Top 10 widgets.
Click a subnet/scope row to open the entity details view with more details.
Click a subnet/scope to go to the subnet/scope details page.
To view the aggregated utilization summary across your organization, review the IP Utilization widgets.
Click a widget header to navigate to the Entity Explorer for the relevant entity (subnets/scopes), ordered by usage.
To view monitored subnets and scopes, open a dedicated view:
For subnets, go to the Subnets tab. The Subnets view lists all monitored subnets, with basic details, such as IP address, CIDR, Mask, IP utilization, and DHCP scopes.
For scopes, click Top 10 DHCP scopes by Utilization (the widget header). The DHCP Scopes view lists all monitored subnets, with basic details, such as IP address, CIDR, Mask, IP utilization, subnet, and DHCP server.
To view DHCP server details, go to the DHCP Servers tab.
Click a server to go to its details view. The details include:
Available IPs
IP utilization
Basic details, such as server name, host, IP address, ...
If you defined VLAN ID and Location on the collector, you can see these in the Additional details section.
Historical cumulative totals since the server started or the server statistics reset.
Discovers: Clients searching for available DHCP servers on the network.
Offers: Servers offering IP addresses and configuration.
Requests: Clients requesting offered IP addresses from a specific DHCP server.
Acks: Servers confirming IP assignments to clients.
Nacks: Servers rejecting clients requests, for example in case of invalid IPs.
Declines: Clients informing the server that the offered IP address is already in use (detected via ARP).
Releases: Clients releasing the IP address when it's no longer needed.
Add subnets manually
Although subnets are discovered automatically from DHCP scopes, you can add standalone subnets manually.
Go to the Subnets view.
Click Add Subnet.
Select the Network Collector to be used for monitoring.
Enter a subnet address and CIDR. The mask and range preview displays.
Click Add. IP addresses are created automatically and scheduled for scanning.
Subnets up to /19 (4096 IP addresses) are created automatically. For larger subnets, you must add IP ranges manually.
Edit subnets
You can rename a subnet or disable auto-scanning for individual subnets.
To rename a subnet:
Click the vertical ellipsis for the subnet and select Edit.
Update the subnet name.
Save your changes.
To disable auto-scanning for a subnet:
Click the vertical ellipsis, select Disable Auto Scanning.
Confirm the action.
Manage subnet tags
Subnet tags help you classify and organize subnets by using user-defined categories and values. They provide a flexible way to group, filter, and manage subnets without modifying the subnet configuration.
Changing subnet tags only affects how subnets are organized and displayed within IP Address Management. Modifying tags does not change subnet addresses, scanning settings, or any other subnet functionality.
Required permissions
Users must have member permissions to create, modify, assign, or delete subnet tags. Without these permissions, users can only view tags.
Best practices for creating subnet tags
Use self-descriptive names and avoid ambiguity.
Examples: Location, Environment, Owner, Type
Limit the number of categories and focus on business-relevant classifications.
Access subnet tags management
Click Manage Subnet Tags. The dialog displays all subnet tags available in your organization.
To find a tag, start typing the tag name into the search box.
Add subnet tags
On Manage Subnet Tags, click Add Subnet Tag.
Enter a name for the new tag.
Add one or more values for the tag.
Save your settings.
The tag is created and added to available tags.
Delete subnet tags
On Manage Subnet Tags, click the vertical ellipsis for the tag you want to delete.
Select Delete and confirm the deletion.
The tag, all associated tag values, and all related subnet assignments are deleted.
Assign subnet tags
In the Subnets view, select one or more subnets.
Click Assign Subnet Tags. The Assign Subnet Tags dialog opens.
For each tag category you want to assign, select a value from the drop-down list.
If the tag is not available, click Create New Subnet Tag, define the tag and values, and then click Assign.
Click Assign.
The selected tags are assigned to the selected subnets.
Remove an assigned tag
On Manage Subnet Tags, select one or more subnets.
Click x next to the tag you want to remove.
Click Assign.
The subnet retains the remaining assigned tags. The removed tag is no longer assigned to the subnet.
View tags for subnets
In SolarWinds Observability SaaS, click Network > IP Address Management > Subnets.
Find the Subnet Tags columns.
Review tags assigned to subnets in this column.
Group subnets by tags
Find the Group by Subnet Tag control.
Select a tag category.
The subnets list is organized into groups based on the selected tags.
Add IP addresses
Use these steps to re-add removed IP addresses or to define scanned IP ranges within large subnets.
Click a subnet to open the subnet details view with a list of all IP addresses in the subnet.
Click Add IP.
Specify the IP range (starting IP, the ending IP address), and click Add.
New IP addresses in the range are enabled for monitoring. Existing IP addresses are unchanged.
Change IP address status
Subnet scanning identifies the status of individual IP addresses. You can manually change an IP address status when necessary.
Click a subnet to open its details view, which lists all IP addresses in the subnet.
Select one or more IP addresses, and then click Change Status.
Select the new status for the selected IP addresses, and then confirm your selection.
Available statuses include:
Available
Used
Reserved
This status is available only when the subnet is associated with a managed DHCP scope on the server.
Limitations for reserved IP addresses
Only DHCP reservations are supported. Legacy BOOTP reservations are not supported.
Infoblox servers are read-only. You cannot create reservations remotely on these servers.
KEA DHCP reservations: To create or manage reservations on KEA servers, you must use Network Collector version 2026.4 or later.
Marking an IP address as Used does not create a DHCP exclusion and does not prevent DHCP assignment when the range is DHCP‑managed. This option is intended for manual tracking in static IP ranges.
The IP address status is updated.
Remove IP addresses
Select one or more IP addresses and click Remove.
Confirm the removal.
The IP address is no longer monitored.
Remove subnets from scanning
Click the vertical ellipsis for the subnet to remove and select Remove.
The subnet is no longer monitored with SolarWinds Observability SaaS.
Alerts and dashboards
You can create custom alerts and dashboards for DHCP servers, DHCP subnets, and scopes.
Log in to the Network Collector web console using an account with Administrator privileges.
To add a DHCP server:
Click Settings > All Settings > DHCP and DNS Management.
Click Add and complete the Add DHCP Server wizard.
The initial scan starts automatically and may take up to 30 minutes, depending on the number of scopes/subnets and the managed IP space. Discovered DHCP scopes and subnets are imported and displayed under Network > IP Addresses.
The folders and hierarchy structure is not yet exported and represented. All is flat.
To add a stand-alone subnet:
Click Settings > All Settings > Manage Subnets & IP Addresses.
Click Add > Subnet, specify the subnet details (name, IP address, CIDR notation), and save your data.
Data appears in SolarWinds Observability SaaS after the initial scan and updates every 15 minutes.
Configure IP monitoring for Platform-connected SolarWinds Observability Self-Hosted
To monitor IP addresses managed in SolarWinds Observability Self-Hosted, configure Platform Connect to stream data to SolarWinds Observability SaaS.
To use Platform Connect, a commercial SolarWinds Observability Self-Hosted license must be activated on your SolarWinds Platform server.
Copy or create an API token (Ingestion type), found in the settings area of SolarWinds Observability SaaS. See API Tokens for details.
In the SolarWinds Platform Web Console settings, open Platform Connect.
Install and configure the SolarWinds Observability Agent, using the API token created earlier.
See Connect SolarWinds Observability Self-Hosted to SolarWinds Observability SaaS with Platform Connect for details.
On the Configure Agent screen, ensure IP Management items are enabled.
After Platform Connect setup, the data is available in SolarWinds Observability SaaS.
DNS data is not exported to SolarWinds Observability SaaS yet.
