Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Device Matrix
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Kiwi CatTools supports a wide range of different manufacturer and model devices and works with the most common and up-to-date CLI syntax. Use the device matrix to determine whether or not a device is supported to the level you require. The list provides a current list of device types that function with KCT and also identifies the level of support that each of those scripts contains:
If you are unable to get your device to work properly with Kiwi CatTools, it is likely due to one of the following issues:
  • The device is not supported by Kiwi CatTools.
  • The activity you are trying to run is not configured correctly.
  • The device is using a different CLI syntax than what is expected by Kiwi CatTools.
SolarWinds recommends inquiring via THWACK, the SolarWinds online community for additional information, or contact support.
Configuring device variations
There are a number of device specific script variables that Kiwi CatTools uses during the execution of certain device scripts. To avoid errors and to run device specific variables, device variations are provided in Kiwi CatTools. For information on how to configure these device variations, see How to use variations in Kiwi CatTools.
Legend
Supported.png Supported by Kiwi CatTools.
NotCurrentlySupported.png Not currently supported by Kiwi CatTools. Please inquire on THWACK.
NotSupported.png Not supported by the device.
PartialSupport.png Partial support.
Unknown.png Unknown. No analysis was possible.
Activities
The following Activities require no device login:
Devices Update Banner Inter-device Ping Connectivity Login Test Update Password Backup Running Config Backup Config TFTP Send Com-mands Modify Config TFTP Upload
3Com.Switch.5500 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
3Com.Switch.SSII NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Accton.Switch NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Addpac.APOS NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Adtran.Netvanta.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Alcatel.Switch.Omnistack NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
AlliedTelesis.AlliedWare.Plus NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
AlliedTelesis.Switch.8000 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
AlliedTelesis.Switch.8500
APC.AOS NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
APC.AOS.CLI NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Aruba.ArubaOS.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
ATI.Router.General NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
BelAir.SwitchRouter.Wireless
Bluecoat.Cacheflow NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Brocade.Switch NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Checkpoint.VPN NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.ACE NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.CallManager NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Firewall.ASA Supported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Firewall.IDS NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Firewall.PIX
Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.MDS.Fibre NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.NXOS NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Older.VPN3002 NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.ACNS
Cisco.Other.CSS NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Other.CUE
NotSupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.LocalDirector NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.VPN3000 NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Router.General Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.Router.noenable NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.SCE NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.SmallBusiness NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Switch.1900 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Switch.CatOS Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.Switch.IOS Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.Terminal.Server NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.V4.1.VPN3000 NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.VPN NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.WAE NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Cisco.Wireless.Lan NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.WLSE NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Citrix.NetScaler.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Crossbeam.COS NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Crossbeam.UTM NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cygwin NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Dell.Switch.CLI NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
DLink.Switch.General NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
DLink.Wireless NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Matrix.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Enterasys.MatrixN.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Router.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Router.XSR1800 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Securestack NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Wireless.Controller NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Extreme.Switch.General NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotSupported.png NotCurrentlySupported.png
F5.BigIP
F5.BigIP.GTM NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
F5.BigIP.TMSH NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
FiberLogic.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Force10.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Fortinet.FortiOS
Fortinet.FortiOS.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Foundry.Switch.General Supported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Foursticks.NP.Gateway NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
GarrettCom.Switch.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Generic.Device NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
Gigamon.Router.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
HP.Switch.2500 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
HP.Switch.5800 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
HP.Switch.Aruba NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
HP.Switch.Others NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Huawei.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
IBM.AIX.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
IronPort.Security.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Juniper.App.Accelerator-DX
Juniper.Application.Accelerator NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Juniper.Netscreen.Firewall NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Juniper.Router NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Lancom.ISDN.Router NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Lantronix.EDS NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Linux.RedHat.Bash NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
McData.Fibre NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Meru.Controller.MC
Mikrotik.Router
Motorola.Router.CMTS NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Motorola.Vanguard NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
MRV.Switch.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
MultiCom.Firewall.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
NEC.Univerge.IX
NEC.Univerge.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
NetApp.FAS.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Netgear.Switch.General NotSupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Netopia.DSL NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nokia.ADSL.M1122
Nortel.Application.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.ARN.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Nortel.Router.VPN
Nortel.Secure.Router NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Nortel.Switch.Ethernet NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
Nortel.Switch.NoCLI NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Switch.Passport NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Nortel.Wireless.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Occam.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Packeteer.Packetshaper NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
PaloAlto.FireWall NotCurrentlySupported.png PartialSupport.png Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
Pannaway.BAR NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Pannaway.BAS NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Radware.AppDirector NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Radware.WSD NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Redback.Router.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Riverbed.Steelhead NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Riverstone.Router.General NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Sidewinder.Firewall NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
SonicWall.SonicOS
Sun.SunOS.General NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Symbol.WS2000 NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Thomson.Speedtouch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Trapeze.Wireless.Lan NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Xirrus.Wireless NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
ZyXEL.Switch NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png
Reports
The following Reports require no device login:
Devices Version Report Compare Running Startup Port Report MAC Report ARP Report CDP Neighbours Report Error Info Report
3Com.Switch.5500 Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
3Com.Switch.SSII Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Accton.Switch NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Addpac.APOS Supported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Adtran.Netvanta.General Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Alcatel.Switch.Omnistack NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
AlliedTelesis.AlliedWare.Plus Supported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
AlliedTelesis.Switch.8000 NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
APC.AOS Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
APC.AOS.CLI Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Aruba.ArubaOS.General Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
ATI.Router.General Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Bluecoat.Cacheflow Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Brocade.Switch NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Checkpoint.VPN NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.ACE NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.CallManager NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Firewall.ASA Supported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png
Cisco.Firewall.IDS Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Firewall.PIX
Cisco.MDS.Fibre Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.NXOS Supported.png PartialSupport.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.Older.VPN3002 NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.ACNS
Cisco.Other.CSS Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.CUE
Cisco.Other.LocalDirector NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.VPN3000 NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Router.General Supported.png PartialSupport.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.Router.noenable Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png Supported.png
Cisco.SCE NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.SmallBusiness Supported.png PartialSupport.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Switch.1900 Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Switch.CatOS Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png
Cisco.Terminal.Server NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.V4.1.VPN3000 NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.VPN Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.WAE Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Wireless.Lan Supported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.WLSE NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Citrix.NetScaler.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Crossbeam.COS NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Crossbeam.UTM NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cygwin NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Dell.Switch.CLI Supported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
DLink.Switch.General NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
DLink.Wireless Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Matrix.Switch NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.MatrixN.Switch NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Router.General Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Router.XSR1800 Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Securestack NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Enterasys.Wireless.Controller Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Extreme.Switch.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
F5.BigIP
F5.BigIP.GTM Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
F5.BigIP.TMSH Supported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
FiberLogic.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Force10.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Fortinet.FortiOS
Fortinet.FortiOS.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Foundry.Switch.General Supported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Foursticks.NP.Gateway NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
GarrettCom.Switch.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Generic.Device NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Gigamon.Router.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
HP.Switch.2500 Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
HP.Switch.5800 Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
HP.Switch.Aruba NotCurrentlySupported.png Supported.png Unknown.png NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png
HP.Switch.Others Supported.png PartialSupport.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png
Huawei.General Supported.png Supported.png NotCurrentlySupported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
IBM.AIX.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
IronPort.Security.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Juniper.Application.Accelerator Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Juniper.Netscreen.Firewall Supported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Juniper.Router Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Lancom.ISDN.Router NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Lantronix.EDS NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Linux.RedHat.Bash Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
McData.Fibre NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Meru.Controller.MC
Mikrotik.Router
Motorola.Router.CMTS NotCurrentlySupported.png NotCurrentlySupported.png Supported.png Supported.png Supported.png NotCurrentlySupported.png Supported.png
Motorola.Vanguard NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
MRV.Switch.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
MultiCom.Firewall.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
NEC.Univerge.IX
NEC.Univerge.Switch NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
NetApp.FAS.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Netgear.Switch.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Netopia.DSL Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nokia.ADSL.M1122
Nortel.Application.Switch NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.ARN.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Router.VPN
Nortel.Secure.Router NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Switch.Ethernet NotCurrentlySupported.png PartialSupport.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Switch.NoCLI NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Switch.Passport NotCurrentlySupported.png NotSupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Nortel.Wireless.Switch NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Occam.General NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Packeteer.Packetshaper NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
PaloAlto.FireWall NotCurrentlySupported.png PartialSupport.png Supported.png Supported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Pannaway.BAR Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Pannaway.BAS Supported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Radware.AppDirector NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Radware.WSD NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Redback.Router.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Riverbed.Steelhead NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Riverstone.Router.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Sidewinder.Firewall NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
SonicWall.SonicOS
Sun.SunOS.General NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Symbol.WS2000 NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Thomson.Speedtouch NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Trapeze.Wireless.Lan Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Xirrus.Wireless NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
ZyXEL.Switch NotCurrentlySupported.png Supported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png NotCurrentlySupported.png
Connections
Other connection methods are also supported by certain devices. See Connecting via a session in the Kiwi CatTools Administrator Guide.
Devices Login Telnet Login SSH Login ConnectVia
Alcatel.Switch.Omnistack Supported.png Supported.png NotCurrentlySupported.png
AlliedTelesis.AlliedWare.Plus Supported.png Supported.png NotCurrentlySupported.png
ATI.Router.General Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Firewall.PIX
Cisco.Other.ACNS
Cisco.Other.CSS Supported.png NotCurrentlySupported.png NotCurrentlySupported.png
Cisco.Other.CUE
Cisco.Other.LocalDirector Supported.png Supported.png NotCurrentlySupported.png
Citrix.NetScaler.General Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Matrix.Switch Supported.png Supported.png NotCurrentlySupported.png
Enterasys.MatrixN.Switch Supported.png Supported.png NotCurrentlySupported.png
Enterasys.Wireless.Controller Supported.png Supported.png NotCurrentlySupported.png
F5.BigIP
Fortinet.FortiOS
GarrettCom.Switch.General Supported.png Supported.png NotCurrentlySupported.png
IronPort.Security.General Supported.png Supported.png NotCurrentlySupported.png
Juniper.Application.Accelerator NotSupported.png Supported.png NotCurrentlySupported.png
Juniper.Netscreen.Firewall Supported.png Supported.png NotCurrentlySupported.png
Meru.Controller.MC
Mikrotik.Router
MultiCom.Firewall.General Supported.png Supported.png NotCurrentlySupported.png
NEC.Univerge.IX
Nokia.ADSL.M1122
Nortel.Application.Switch Supported.png Supported.png NotCurrentlySupported.png
Nortel.Router.VPN
Nortel.Switch.Ethernet Supported.png Supported.png NotCurrentlySupported.png
Nortel.Switch.Passport Supported.png Supported.png NotCurrentlySupported.png
Nortel.Wireless.Switch Supported.png Supported.png NotCurrentlySupported.png
Packeteer.Packetshaper Supported.png Supported.png NotCurrentlySupported.png
Riverstone.Router.General Supported.png NotCurrentlySupported.png Supported.png
SonicWall.SonicOS
More information on adding devices
For more information on adding a device, see:
