Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Unsupported activities for a device
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Device types are updated all the time. For an up to date list of the devices types currently available in CatTools and the activities supported for each of the device types, please see the device matrix.
If there is a listing to support your device, but the activity you require is not currently supported by the device type then please contact us using the Technical Support form, providing us with as much detail as you can and if possible a PuTTY capture of the relevant command(s).
