Upgrade the PostgreSQL database in an existing deployment
If you are upgrading WHD from version 12.7.6 and earlier, you can upgrade your existing PostgreSQL database to version 13.3 using the database upgrade utility included with the WHD 2026.2.1 release. When you run the utility, it stops the PostgreSQL service, upgrades the database to version 13.3, and then restarts the PostgreSQL service. When the upgrade is completed, the utility automatically opens WHD, allowing you to log in to the application.
When you run the utility on a system running Microsoft Windows, the utility creates a new local user named PostgreWHD in the Computer Management > Local Users and Groups > Users directory. This user role is integrated with the PostgreSQL 13.3 upgrade configuration and cannot be deleted.
The default whd role is deleted during the upgrade procedure. This ensures that all unauthorized users cannot access the database.
Before you upgrade
Perform the following mandatory procedures on the WHD system:
Back up your WHD database.
Log in to WHD as an administrator.
Click Setup > Database.
In the Database Connection window, click Backup Now.
Change the default PostgreSQL database credentials.
The upgrade procedure deletes the default whd user in WHD. Before you upgrade to PostgreSQL 13.3, be sure to change your default PostgreSQL database credentials. Otherwise, you cannot log in to WHD after the upgrade.
Perform the upgrade
Run the upgrade utility based on your Windows, Linux, or macOS operating system. When the upgrade is completed, the utility creates an upgrade.output.log file that lists the actions taken during the upgrade procedure. You can access the log file in the <WebHelpDesk>/log directory.
Upgrade the database on a Windows system
Perform the following steps on a WHD server running a supported Microsoft Windows or Windows Server operating system.
- Log in to the WHD server as a local administrator.
If the host system is not running Windows Server 2012 R2, go to step 3.
If the host system is running Windows Server 2012 R2, download Windows Management Framework (WMF) 5.1 from the Microsoft Download Center and install the software on your system.
Navigate to the
<WebHelpDesk>>\binfolder.The default location is:
\Program Files\WebHelpDesk>\bin -
Run the
upgradeDatabase.batfile.A PowerShell window displays the upgrade process. Multiple command windows may also open during the upgrade.
When the process is completed, the WHD interface displays a message, stating that the embedded PostgreSQL database is up to date.
Click Continue.
When the upgrade is completed, WHD opens.
In the Log In window, enter your administrator credentials, and then click Log In.
The WHD web console opens.
Upgrade the database on a Linux system
Perform the following steps on a WHD server running a supported Red Hat Enterprise Linux (RHEL), CentOS, or Fedora operating system.
Open a Command window.
Log in as root.
Run the
databaseUpgradeutility located in the<WebHelpDesk>/bindirectory.In the Command window, execute:
sudo /usr/local/webhelpdesk/bin/databaseUpgradeThe Command window displays the upgrade process.
Click Continue.
Upgrade the database on a macOS system
Perform the following steps on a WHD server running a supported macOS operating system.
Using the Finder, navigate to Applications > Utilities > Terminal and open the Terminal application.
In the Terminal window, log in as root.
Modify the kernel parameters to allocate additional shared memory to the new PostgreSQL database. This will prevent database errors when the utility initializes the database.
Execute:
sysctl -w kern.sysv.shmmax=33554432sysctl -w kern.sysv.shmmin=1sysctl -w kern.sysv.shmmni=256sysctl -w kern.sysv.shmseg=64sysctl -w kern.sysv.shmall=8192 -
Navigate to the
<WebHelpDesk>/bindirectory.The default location is:
/Library/WebHelpDesk/bin -
Run the
databaseUpgradeutility.The Terminal window displays the upgrade process.
Click Continue.
