Features and limitations of the SEM FIPS edition
The SEM FIPS edition, introduced in SEM 2026.4, runs on a customer-managed Red Hat Enterprise Linux (RHEL) host with FIPS mode enabled and uses only FIPS 140-3 validated cryptography. To meet FIPS requirements, some features are removed or work differently than in the SEM virtual appliance.
Use the following tables to plan a FIPS edition deployment.
Features removed in the FIPS edition
| Feature | Details and alternatives |
CMC console and cmc user |
The CMC console and the The |
| CMC password change at first login |
The first-login wizard does not include the CMC password-change screen. |
| Platform Connect and Anomaly Detection |
Platform Connect is not available. The Anomalous Events screen, the Platform Connect update elements, and the Platform Connect status icon are removed. Anomaly Detection is not available. |
| SMB sharing |
SMB sharing is removed from Settings > Sharing because the SMB library depends on a non-FIPS cryptographic provider. Use SFTP or Email sharing instead. See Set up SFTP connections to external systems. |
| Legacy agents |
Legacy agents that use the old communication certificate are not supported. Non-FIPS agents cannot connect to a FIPS edition Manager. Use the FIPS agent installers. |
Features that work differently in the FIPS edition
| Feature | FIPS edition behavior |
| LDAP |
LDAP connections must use LDAPS. See Configure LDAP for SEM. |
| Local user passwords |
Passwords for local users must include at least 14 characters. The default |
| Reset the admin account |
Run |
RHEL root password |
You manage the RHEL |
| Network configuration |
IPv4-only and dual-stack (IPv4 and IPv6) networks are supported. Configure networking with RHEL tools such as |
| Internal databases |
Internal databases use SQLite. |
| Certificates and keystores |
Certificates should include a Subject Alternative Name (SAN). Keystores use the BCFKS format. Use |
| SNMPv3 |
SNMPv3 must use SHA authentication and AES privacy. MD5 and DES are rejected. |
| TLS |
ChaCha20 cipher suites are removed. TLS connections use AES-GCM cipher suites. |
| SFTP and SCP |
Non-FIPS algorithms are removed. Older SFTP servers that support only non-FIPS algorithms might not be able to connect. |
| Connector updates |
To update connectors offline, copy the connectors ZIP file to |
| Kerberos single sign-on |
Features that work the same in the FIPS edition
The following features work the same way as in the SEM virtual appliance:
Dashboard
Live Events
Historical Events and reports
Rules
Configure tab
Licensing (online and offline activation)
SFTP and Email sharing
SolarWinds Improvement Program (SWIP)
Query packs
