Documentation forServer & Application Monitor
Monitoring your applications and environment is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Server & Application Monitor (SAM) is also available in a standalone module.
Manage Application Monitor templates page
The Manage Application Monitor Templates page provides options for creating and managing your application monitor templates and assigned application monitors. To access the page, click Settings > All Settings > SAM Settings > Manage Templates.
The page includes the following options. For more information, see Use SAM application monitor templates and application monitors.
Create New Template
Begins the creation of a new application monitor template.
Assign to Group
Assign and unassign templates to groups. Note: AppInsight templates cannot be assigned to groups.
Assign to Node
Assign selected templates to monitored nodes.
Application Discovery
Open the Application Discovery page, where you can select nodes to scan for the applications you want to monitor.
Edit
Allows you to edit the selected template.
Tags
Allows you to edit the tags (descriptive labels) for the selected template.
Copy
Allows you to copy the selected templates.
Import/Export
Allows you to import templates created in other instances of SAM or by contributors to the SolarWinds online IT community, THWACK.
SolarWinds recommends checking THWACK periodically for updates to SAM application monitor templates. With the exception of AppInsight templates, those templates are not updated automatically during upgrades to avoid overwriting custom changes. For details, see Import and export SAM application monitor templates.
Export to THWACK
Allows you to export selected templates to THWACK.
Export as File
Allows you to export selected templates to files for use in other instances of SAM.
Assign Details View
Allows you to specify whether each application details view uses the generic application details view or a custom details view.
Delete
Allows you to delete selected templates.
