Monitor device configurations
When a Network Collector or Platform-connected SolarWinds Observability Self-Hosted polls configuration data, you can see the configurations in SolarWinds Observability SaaS.
The system checks for outdated configurations every 45 minutes. Configurations older than 30 days are deleted.
This topic covers:
Requirements
Configurations are displayed only for nodes with enabled configuration management. You can enable it in one of the following ways:
All built-in roles can access the Configuration Management area overview. For custom roles, the user must have Configuration Management > Configs > View permission under Permissions settings.
Downloading and uploading configs and executing scripts require extra permissions. Only the built-in Owner and Admin roles can perform these actions. For custom roles, the user must have Configuration Management > Configs > Full Access permission.
You can see only the actions you have permission to perform. If you cannot see a menu item, ensure that you have sufficient permissions.
View configurations
In SolarWinds Observability, click Network > Configuration Management. Review the tabs:
Overview: At-a-glance view of configuration management details, such as the number of devices by vendor, backup history, baseline conflicts, and config changes.
Managed Devices: Lists devices with enabled configuration management. Use the search and filter options to find a device. This view provides the following details for monitored devices:
Name
The device name. Click it to open the node details page for the device.
Vendor
The device vendor.
Latest Operation
The result and timestamp of the most recent configuration download.
Success: The latest configuration download completed successfully.
Failure: The latest configuration download failed.
Not performed: No configuration download has been initiated for this device from SolarWinds Observability SaaS. Configurations may be available if they were performed by a job scheduled on the Network Collector from the collector web console.
Latest Running Config
No Backup: No backup available. A config was either never downloaded or it was deleted according to the retention policy, by default after 30 days.
Backed up: Click Backed up to display the configuration in an Inspector Panel.
Latest Startup Config
Startup vs Running
Displays the comparison between the latest downloaded running and startup configurations.
Match
Conflict: Click to open the conflict in the Inspector Panel
Not Comparable: The comparison cannot be performed because the running configuration, the startup configuration, or both are not available.
Running vs Baseline
The comparison of the latest downloaded running configuration with the baseline. See Manage configuration baselines.
Review configurations for a device
Go to Managed Devices (Network > Configuration Management > Managed Devices).
Click a row on the Managed Devices tab to open the Inspector Panel with the device details.
In the Inspector Panel, click the Configurations tab for a list of all configurations downloaded for the device.
Click a configuration to display it.
Compare configurations
Click a device name to open the device details view.
Open the Configuration Management tab.
Select two configurations and click Compare.
Review the changes and click Close to close the content comparison.
Review configuration changes and conflicts
Use available filters to show relevant devices.
If there is a conflict between configurations, you can see Conflict in the Startup vs Running column or in the Running vs Baseline column.
Click the conflict to compare the configurations in an Inspector Panel.
Download configurations
Select one or more devices and click Download Running Config or Download Startup Config.
The configuration download starts. Click the Events link in the message to follow the download progress.
Sign scripts or upload jobs
Some actions, such as uploading configurations or running scripts, require a digital signature before they can run. The signature is generated by using a pair of cryptographic keys: a private key and a public key. You must set up these keys before performing any signed action.
When prompted during an action, run a signing script and paste the output into the Signature field.
Set up signing
Ensure that OpenSSL is installed on your computer and available in your system PATH. See OpenSSL Downloads and Path (Windows commands) for details.
Create a private key. Use the following script to create a 4096-bit RSA private key encrypted with AES-256.
openssl genpkey -algorithm RSA -out private_key.pem -aes256 -pkeyopt rsa_keygen_bits:4096
Create a public key. Use the following script to extract the public key from the private key.
openssl rsa -in private_key.pem -pubout -out public_key.pem
Create the following folder on your Network Collector and paste the public key into it.
C:\ProgramData\SolarWinds\UAMSClient\plugin-storage\nim-actions\signature-public-keys
(Optional) Click Validate to verify that the signing configuration is correctly set up on all Network Collectors involved in the job.
Validation checks that the required public key is available and can be used for signature verification on each participating Network Collector, and returns one of the following statuses:
Success - The signature configuration is valid.
Agent not reachable - Unable to perform validation due to a connection issue with the Agent and/or Network Collector.
Validation failed - The signature is not valid.
You can still save and run the action without performing validation.
Sign actions
When you perform an action that requires a signature, run the provided signing script, and then paste the output into the Signature field.
Signature verification is enabled by default. If you encounter issues, ensure that the following flag is set in the configuration file on the Network Collector.
--EnableSignatureVerificationFeature=true
Upload configurations
Uploading a configuration does not guarantee that the device is fully restored to the selected configuration state. During the upload operation, the current running configuration on the device is merged with the uploaded configuration.
Review the upload script carefully and make any necessary changes to achieve the expected result.
Click the vertical ellipsis next to the device and select Upload Config.
On Upload operation details, review the configuration you want to upload, and then click Next.
You can modify the configuration before uploading it to the device. Changes apply only to the uploaded configuration; the original downloaded configuration remains unchanged.
Additional options:
To write the configuration to non-volatile memory, select the Write to NVRAM box.
To reboot the device after the upload completes, select Reboot.
On the Signing page, select your operating system, copy the provided script, and run it on the device.
Paste the output into the Signature field and click Upload.
The configuration upload starts. To monitor progress, click the Events link in the status message.
Manage and run scripts
Click Network > Configuration Management.
On the Overview tab, open the Script Management tab in the lower part of the view. From there, you can view and manage available scripts by using the vertical ellipsis at the end of each row.
Execute scripts
In Script Management, click the vertical ellipsis for a script, and then select Execute to open the Execute Script wizard.
You can also execute scripts for specific devices from the Managed Devices tab. Click the vertical ellipsis next to the device, and then select Execute Script. In this case, the Select Network Devices step is skipped.
On Script Details, review the script. You can change the script here.
To reboot the device after running the script, select the Reboot box.
On Select Network Devices, select one or more devices on which to run the script.
On Signing, select the operating system, run the provided command-line script, and paste the output into the Signature field. Optionally, add signature validation.
Click Execute.
Delete scripts
In Script Management, click Delete in the vertical ellipsis for a script, and then confirm deletion.
Edit scripts
In Script Management, click Edit in the vertical ellipsis for a script and make your changes.
Add scripts
You can add scripts to run on devices with monitored configurations. For supported operations, see the device vendor documentation.
In Script Management, click Add Script.
Enter a name for the script.
Type your script in the Content box.
Provide more details on why you created the script and what it does in the Comments box.
Save the script.
The script is added to Script Management. You can run or edit it there.
Schedule and manage configuration jobs
Schedule configuration jobs to automate the management of network devices and configuration files. Configuration jobs include regular downloads of device configurations.
You can define and run configuration jobs either in SolarWinds Observability SaaS, on the Network Collector/Platform-connected SolarWinds Observability Self-Hosted, or in both places.
- Supported job types: Download Configurations from Devices, Upload Change to Devices, Execute Command Script on Devices.
- There are no predefined jobs.
Network Collector /Platform-connected SolarWinds Observability Self-Hosted
- Supported job types: Download Configurations from Devices, Upload Change to Devices, Execute Command Script on Devices. See NCM job types for a comprehensive list.
- There are predefined daily jobs.
Before you create a new job in SolarWinds Observability SaaS, check whether a similar job already exists on the Network Collector/Platform Connect SolarWinds Observability Self-Hosted. If you find the job there, consider disabling the job to avoid duplication.
View existing configuration jobs
See all scheduled jobs on the Configuration Management Overview in SolarWinds Observability SaaS. Go to Network > Configuration Management > Scheduled Jobs tab. From here, you can also navigate to Job Management.
Create a configuration job
In SolarWinds Observability SaaS, go to Settings > Configuration Management > Job Management.
Click Create.
Name the job.
Select a Job Type:
Download Configs from Devices
Upload Changes to Devices
On the Schedule screen, specify when the job runs. Select the frequency (Daily, Weekly, Monthly, or Specific Date) and complete the schedule definition.
Select the devices to target with this job using one of the following methods, then click Next.
All Devices: Target all devices with enabled Configuration Management.
Selected Devices: Manually select one or more specific devices.
Dynamic Selection: Automatically target devices based on matching criteria, such as vendor, model, or custom tags. To filter by tag, use tags.Name as the attribute and enter the tag value.
Only devices that have communicated with SolarWinds Observability within the last 24 hours are included when the job runs. Devices that have not communicated within this period are automatically skipped.
If a Network Collector has not reported data within the last 24 hours, devices managed by that collector are skipped and no error is generated in the job report.
Specify how you want to be notified about the job:
Select an available email configuration. See Email notifications
Custom Trigger Notifications and Custom Reset Notifications are not supported. If you select a configuration where these options are enabled, the job will run but you will not receive any notification.
Click Add a new configuration, provide a name for the email configuration and enter recipients. Optionally, enter a description for the email configuration.
Configure job-specific details and click Next.
Download Configuration: Select the configuration type to be downloaded - Running, Startup, or both. If you select both options, you can include both configuration types in a single job.
Upload Changes: Select a device and then select the configuration to upload to the device. Review the configuration, adjust it, or select an additional option if necessary. See Upload details.
Execute Command Script on Devices: Select an existing script or write a script to run on the devices. When you select an existing script, the script is displayed. You can adjust the script.
If the job requires a signature (uploading changes or executing commands), sign it and click Next to continue. You also have the option to set up signature validation, which returns one of three statuses: Success, Validation failed, and Agent not reachable. See Set up signing for configuration details.
On Signing, select the operating system of the device.
Copy and run the command line script.
Paste the output to the Signature field.
Review the summary and save the job. The job is added to the Job List. By default, new configuration jobs are enabled and run as scheduled. Review the Status column.
Enable/disable configuration jobs
Configuration jobs must be enabled to run. Jobs that are not enabled will not start.
Find the job you want to enable/disable, click the vertical ellipsis and select Enable/Disable.
Edit configuration jobs
Find the job you want to edit, click the vertical ellipsis and select Edit. This starts the Update Job wizard, where you can change the name, schedule, devices, notification and job-specific details. See Create a configuration job for details about the wizard.
Monitor job execution
Review job details
Click a job to display more details in the Inspector Panel.
Click the Records tab in the Inspector Panel to see the transfer history. If there are no records, select a longer time range in the Show drop-down list.
Review job activity
In SolarWinds Observability SaaS, go to Network > Configuration Management > Configuration Management.
Click the Activity Log tab in the lower part of the screen. The tab displays all transfers for all jobs.
Use the filters to find a specific job, or access the Activity Log tab from a specific job.
If there are no records, select a longer time range in the upper right corner.
To view more details for a specific job, click the vertical ellipsis for the job and select View Details. For download jobs, this lists all downloaded configurations. If a script execution job fails, details include the failure reason.
Review scheduled jobs
Click the Scheduled Jobs tab in the lower part of the screen. The tab displays all enabled jobs that have a scheduled execution.
Use the filters to find a specific job.
If there are no records, verify that scheduled jobs are enabled or adjust the selected time range, if applicable.
Click a job to open the Inspector Panel and review additional details about the scheduled job.
Click the Logs tab in the Inspector Panel to view the execution history and results for the selected job. If there are no records, select a longer time range in the Show drop-down list.
