Top XX Autonomous Systems Conversations
This widget provides a list of the most bandwidth‑intensive autonomous systems conversations. Autonomous systems conversations are listed with the amount of data (kbps) transferred, in both bytes and packets, and the percentage of all traffic generated by the autonomous system over the specified time period.
To find out more about autonomous systems monitored by NTA, see Managing Autonomous System Networks.
When placed on the Node Details or Interface Details view, this widget provides a view of the autonomous systems conversations responsible for the most traffic passing through the viewed node or interface over the selected period of time.
View more details about displayed autonomous systems conversations
Click a listed autonomous systems conversation to open it in the NetFlow BGP Summary View.
Click + to expand a listed autonomous systems conversations and display a list of nodes and their respective interfaces relevant for the selected autonomous systems conversation.
Click a listed node or interface to display the relevant autonomous system conversation traffic traversing through the selected node or interface in the NetFlow Autonomous Systems Conversation View.
Table legend
The table below the chart provides the following information:
Column Title | Contents |
AS to AS Conversation | The autonomous system conversation endpoints with IP addresses in parentheses. |
Ingress Bytes, Egress Bytes Ingress Packets, Egress Packets |
Displays the amount of data (in bytes and packets) flowing in the selected autonomous systems conversation through the viewed node or interface. The columns displayed depend on the flow direction set in the top left corner of the view (either only Ingress Bytes, or only Egress Bytes, or both columns). |
Percent (Utilization) |
Displays the percentage of all traffic through the viewed object that can be attributed to the appropriate autonomous systems conversation. The first value describes the percentage of the appropriate item based on items shown by the chart. Individual items in the legend add up 100%. This percentage can be absolute or relative. For more information, see Set the Percentage type for Top XX lists. A value in parentheses is available only for interfaces. It describes how the appropriate item utilizes the interface bandwidth in percentage. If the utilization is approximately twice as high as it should be, for example 150% instead of 75%, it might be caused by flow duplication. For more information, see Resolve duplicate flows. |
Edit the widget
If you are logged in using a User ID with administrative privileges, you can change the way this widget is displayed for all users:
- Click Edit to load the Edit Resource page.
- Make changes.
- Click Submit.
Edit time and flow direction for the view
You can also change the time period and flows direction shown by all widgets in the view:
- Directly below the view name, click
next to the appropriate setting and define the appropriate settings.
- Change the Relative Time Period, by default set to 1 hour prior to the current time, or specify a specific time period.
The time and flow direction settings are limited to the current session only. After you leave the view, your changes will be lost and default settings are re-applied.
