Monitoring network performance is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. Network Performance Monitor (NPM) is also available in a standalone module.
Custom Interface Chart
The Interface Details view may be customized to display any of the interface‑relevant charts listed in the following table.
Custom Interface Charts
Percent of Modems Online
Percent of Modems Registered
Total CATV Channel Modems
Total Active CATV Channel Modems
Min/Max/Average bps In/Out
Min/Max/Average Percent Utilization
Min/Max/Average bps Received
Min/Max/Average bps Transmitted
Min/Max/Average Transmit+Receive bps
Min/Max/Average Transmit+Receive % Utilization
Average bps - Line Chart
Average bps - Step Chart
Percent Utilization - Step Chart
Percent Utilization - Line Chart
Min/Max/Average Packets In/Out
Average Packets per Second
Total Bytes Transferred
Total Packets Transmitted/Received
In/Out Errors
In/Out Discards
In/Out Errors and Discards
Multicast Traffic
Percent of Modems Online and Registered - Line Chart
Total Registered CATV Channel Modems
Customize the chart
Drop-down menu options
To quickly modify the chart, select any of the following options from the drop-down menu:
  • View chart data over the Last 7 Days
  • View chart data over the Last 30 Days
  • Select Edit Chart to open the Custom Chart page for customizing the presentation of this chart.
  • View Chart Data as an HTML‑formatted document
  • View Chart Data in Excel to see chart data in an Excel™‑compatible format
Custom Chart page
Click the chart to open the Custom Chart Page. This page shows the chart with a number of customization options in the Customize Chart area.
Edit page
Click Edit to select the chart type, time period or sample interval shown in the chart. See Edit resource for information about further customization options.
Customization tips
Sample interval and time periods
  • Each sample interval is represented by a bar. Data within a selected sample interval is summarized automatically.
  • Some charts may not display due to large amounts of historical data or short sample intervals, and may decrease performance.
Display calculated lines
Add lines to the chart representing important values so that you know at first sight when the values are getting near to an important level.
Click Edit, select a line, and submit your changes. The lines will be displayed in the chart.
Show trend
Select Show a Trend Line to display a line representing potential future results. This line is extrapolated from collected historical data, and is thus only an approximate prediction of future data.
Trend lines on charts are intended as approximate predictions of future data. This is because there are many reasons that can affect the performance of devices on your network.
Percentile 95th
Select Show the 95th Percentile line to include a line marking the 95th percentile for the data collected over the indicated time period.
