Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Options menu
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Options menu allows you to change the setup options in Kiwi CatTools.
Menu option Description
Setup
This menu item displays a form that enables you to set the general properties of CatTools.
  • The Email tab allows you to set all the emailing properties.
  • The Logging tab enables you to set CatTools to send syslog messages to a syslog server and provides control over information and activity logging functions.
  • The Misc tab allows you to set miscellaneous settings.
  • The TFTP Server tab contains the settings for controlling the CatTools TFTP server.
  • The DNS Resolver tab contains the settings for resolving IP Addresses in ARP reports.
Device Wizard
The Device Wizard helps guide you through the addition of new devices to the CatTools database.
Alternatively you can add new devices from the Devices pane.
Activities Wizard
The Activities Wizard helps guide you through the addition of new activities to the CatTools database.
Alternatively you can add new activities from the Activities pane.
