Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Activities Pane
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
This pane displays all the activities you have defined. Right-clicking in the pane brings up a context menu allowing customization and access to core functions.
Option Description
Add activities
Add a new activity using Add a new scheduled activity.
Edit activities Edit an existing activity using Edit scheduled activity details.
Copy activities Copy an existing activity using Edit scheduled activity details.
Run now
Immediately runs a new or edited activity that is selected from the grid.
Start timer
Starts the activity timer and runs scheduled activities. When the timer is active, any selected activities with set schedules run at the specified interval you have set for them.
Remove activities
Delete the selected activity.
