Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Logging tab
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Logging tab allows you to configure which types of logs to send and where to send those logs: to a syslog server or to a local log file. You optionally can send logs to both locations for redundancy.
Syslog
Send logs to Syslog Server
Enable sending of log messages to syslog server.
Syslog Server
Name or IP Address of the target syslog server that you want your logs sent to.
Protocol
Specify the syslog protocol: UDP or TCP.
The default protocol is UDP.
Port
Valid port number syslog messages are coming through.
The default port for UDP is 514.
Facility
Select the facility setting for outgoing syslog messages. The facility determines the program logging the message. Depending on the facility selected, the messages are handled differently.
The default facility setting is Local0.
Logging Level
Select what level of log messages are forwarded to the target syslog server.
The default logging level is "Info and above".
Format
Specify the syslog message format: None, RFC 3164, or RFC 5424. For more, see Syslog formats.
The default format is None.
Test Syslog
Send a test message to the target syslog server, using the options selected above. This option verifies your configuration and network connection.
Info log
Log info log messages to local log file
Enable info log messages to be logged to a local log file. The default is On.
The log file created is named "InfoLog.txt" and can be found in the CatTools install folder.
Logging level
Select what level of messages are to be logged to the local file. The default level is "Debug and above".
Limit File size
The log file can become rather large if the logging of debug messages is enabled. By checking this option you can limit the size of the info log to the size specified in the size field.
When the log file size reaches the limited size, the file is closed, renamed to infolog_prev.txt, and a new log file is created.
The previous log file is kept in case there is a requirement to go back in the log further than what is contained in the current log. This previous log is deleted before a current log that has reached maximum size is renamed.
The effect of having this option turned on is that there are two log files, a current and a previous.
If the option is set off, the log file grows indefinitely.
Activity log
Log Activity summary to local log file
Enable the CatTools activity summary to be logged to a local log file. The default is On.
The log file created is named "Activitylog.txt" and can be found in the CatTools install folder.
Limit File size
Limit the size of the info log to the size specified in the size field.
When the log file gets to this size, it is closed, renamed to activitylog_prev.txt, and a new log file is created.
